Question about Zenith A32B41W 32" TV
Tv stuck in zoom mode?`
I recently unplugged and moved my Zenith tv. When I plugged it back in and hooked everything back up the screen is now in a zoom mode of some sort. Any help please?
  • Johnnym35 Apr 10, 2008
    the picture seems wider than the screen
SOURCE:
techman
  • 3130 Answers
SOURCE: Tv blew up
sounds like the typical power supply or sweep problem in the zenith chassis. depending on how old this set is will determin if its even worth trouble shooting or taking it in to be looked at by a pro. If your not experienced with tv repair i would call a repair shop or take it in as tv sets have high voltage stored in them even after they have been unplugged for a while. If youve tinkered with tvs in the past or know someone who does zenith tvs are made for a complete chassis exchange. you can Call PTS Corp at 1 800 844 7872 and see how much an exchanged referbished chassis would cost and go from there. Good Luck
Posted on May 24, 2006
SOURCE: Zenith rear projection TV
it's unual for all 3 crt's to go bad at same time, so have you tried turning up screen(G2) control? If so also there is a cap in the high voltage line that when replaced may lighten up set. Don't have model so I can't go further.
Posted on Aug 12, 2007
jimbo4026
  • 50 Answers
SOURCE: can't get my zenith TV off Video mode
not sure what year this tv is, but I had some where the tuner was bad and would be stuck on video. The only way is replacing the tuner. Or you may want to try hooking up a vcr into the video audio jacks and run the channels from the vcr it may work yet.
Posted on Nov 28, 2007
SOURCE: An old zenith tv
TV HAS SOUND BUT NO PICTURE
Posted on Aug 06, 2008
SOURCE: Zenith seq stereo tv, stuck in aux mode
large black box in the center of tv screen
Posted on Jan 17, 2011
Zenith stuck in aux mode
Reset the TV to its factory settings. If it do not help you, the main system memory IC should be replaced. To reset the TV; unplug it from AC mains wall socket, and re-plug it back after five minutes or so.
Aug 12, 2012 | Zenith B25A74R 25" TV
I have no sound from Xbox HDMI connection.
you likely connected it with one or both units involved on and HDMI does not like that--prone to all sorts of audio issues.
If in doubt unplug the units and wait and plug back up making the connections first.
Jun 07, 2012 | Zenith " 50"" Class - Plasma - 720p -...
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Jan 15, 2009 | Zenith Televison & Video
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
Akai stuck on zoom??
Run it through the different 'MODE' settings. it may really be on zoom, or just confused.
Also, try unplugging it for a minute. plug it back in and see if it's better.
Aug 15, 2008 | Televison & Video
Stuck in zoom
You should be able to get to the menu with the front panel buttons. Otherwise, try unpluging for a minute, this may allow a reset. Please do not rate me if this is no help.
Apr 23, 2008 | Polaroid FLM-323B Television
Can't get my zenith TV off Video mode
Oct 03, 2007 | Zenith SY1931SG TV
Televison & Video Logo
133 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
