Question about Casio FX-9860G Graphic Calculator
Solve comlex equation
How I can solve asolve comlex equations with fx-9860g
  • Anonymous May 04, 2009
  • Anonymous Mar 27, 2014
    Solve two equation one 1st degree and another two degree with two variable x,y
  • Casio Master
  • 7,993 Answers
I do not understand what you mean by solve complex equations, but if you want to manipulate complex numbers here are the tools you need to enter your complex numbers. Operations and function evaluations do not need special symbols.
solve comlex equation - b4c488c.jpg Hope it helps.
Posted on Oct 01, 2009
    New Friend:
But that mode is to solve a simple complex numbers' calculations.. Genuis, we need to solve an equation of comlex "with unknowns of complex cooficients..
Posted on Dec 05, 2012
Edit Casio FX - 9860G SD have complex equations??
Thhe Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Addendum.
The calculator CANNOT solve equations with complex coefficient. YOU can however convert the system of linear equations with ccomplex coefficients ( of the type you show) as a system of 4 linear equations in 4 unknowns; Split x into a real and an imaginary part, split y into a real and an imaginary part. Substitute Real(x)+iIm(x) for variable x in the equations; substitute Real(y)+iIm(y) for y in the two equations; do the algebra. In each of the original equations split the Real and imaginary parts. You should be able to derive 4 linear equations in unknowns Real(x), Im(x), Real(y), and Im(y).
Use the linear equation solver to obtain the solutions. Recompose x=Real(x)+iIm(x), and y=Real(y)+iIm(y)
Alternatively, after you create the system of 4 linear equations you can use the matrix utility to find Real(x), Im(x), Real(y) and Im(y) and recompose the x and y.
Mar 17, 2012 | Casio FX-9860G Graphic Calculator
Casio FX - 9860G SD have complex equations?? edit
The Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Addendum.
Mar 17, 2012 | Casio Office Equipment & Supplies
Your question (?) is not clear so I will not try to guess what you really mean.
Be it as it may, the Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Mar 16, 2012 | Casio FX-9860G Graphic Calculator
Mar 16, 2012 | Casio Office Equipment & Supplies
Mar 16, 2012 | Casio FX-9750GPlus Calculator
Hello How to solve complex equations using casio fx 9860G AU For example (2+i)A+B=6 2A+(1+i)B=1 How to solve A and B using this calculator
The simultaneous equation solver requires the coefficients to be real. Similarly matrices must have real coefficients.
Your only alternative is to express each of A and B as a real part and imaginary part.
A= x1+iy1
B=x2+iy2.
Substitute x1+iy1 for A in the two equations. Substitute x2+iy2 for B in the two equations. Do the algebra. Gather real parts and gather imaginary parts. Split each original equation into two equations: One equation comes from setting Real Part of left side = real part of right side (1); the other equations comes from setting the imaginary part of left side= imaginary part of right side (here 0).
Do the same procedure for the 2nd original equation.
At the end of the process you will have 4 coupled linear equations in the 4 unknowns (x1,y1,x2,y2).
Then you might want to use the calculator to solve the derived system. Once you have x1,y1,x2,y2 you reconstruct A=x1+iy1, etc.
Aug 29, 2011 | Casio FX-9860G Graphic Calculator
How to input cos x=0.75?
I assume that if you want to input the equation it is with the intent to solve it. If that be the case then what follows will help you input and solve any equation (linear, quadratic, trig, etc.)
Make sure the calculator angle unit is the same as your problem requires (degree, radian, grad). Here are some screen capture to help you. Change the equation to yours. 21c8779.jpg4b6c1ea.jpg
To enter the equation in screen above, use the right arrow.
You have to enter an initial guess on line X=, a default value may be supplied by calculator: It depends on last value stored in X. Once a value is entered press the F6 key to SOLV
Press F1: Rept if you want to solve another equation.
Nov 13, 2010 | Casio FX-9860G Graphic Calculator
SOLVE LINEAR EQN IN FX 9860GII
Let us hope the site does not act starngely. Here are some screen capture to help you.
Oct 08, 2010 | Casio FX-9860G Graphic Calculator
My casio fx-9860G au, wont copy equations from statistic mode to graphic mode. can you please tell me how i can fix this?
Just in case you did not find the Copy function I am including this screen capture from the FX-9860G SD.
The function is available at the bottom of the screen that displays the regression curve. Press Copy and select a function Y1= or Y2=. The next time you press the Draw tab the scatter plot and the regression curve will be displayed on the same screen.
Aug 15, 2010 | Casio FX-9860G Graphic Calculator
Casio FX-9860G Graphic Calculator Logo
893 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
