Question about 2wire (1000-400108-001) Router
2wire 270HGV-W probelem
Well my modem wont connect to the internet it says unable to connect to bigpond but when i connect my other modem it works perfectly the internet light is red on my modem but on the other one it is green what do i do is the modem broken or am i doing something wrong????
    Scholar:
  • 132 Answers
Make sure that your new modem is configured with the correct settings that your ISP requires you to have. Contact your ISP tech support and make sure that the modem is set up properly.
Posted on Nov 08, 2008
Connects only local network unable to brows internet
you should connect your modem to the internet in order to browse or you should have internet connection
Feb 10, 2011 | 2wire (1000-000057-000) Modem
My 2wire product seems to need resetting every few minutes. As soon as it's unplugged and plugged back in, it works. However, after a few minutes, it loses connection again. Is this an issue with my ISP,...
  • Re-run the Setup Wizard using one of the following methods if you are unable to browse the Internet:
  • Re-run the HomePortal Setup Wizard from the HomePortal CD.
  • Re-run the HomePortal Setup Wizard by going to http://homeportal/setup (http://172.16.0.1/setup) in your Web browser.
  • (For Windows only.) Re-run the HomePortal Setup Wizard by clicking Start > Programs > 2Wire Gateway > Run 2Wire Setup Wizard.
If required, make sure that you are using your unique username and password. If the problem persists, contact your ISP to verify your connection type and login information (if necessary). After verifying your connection type, also verify that you are using the correct keycode by referring to your HomePortal documentation or by visiting http://www.2Wire.com/keycode.
Nov 04, 2010 | 2wire (1000-000057-000) Modem
How can i use the wi fi from 2Wire 2701HGV-W modem - ADSL - BigPond
the wifi information is inthe bottom of mdoem
ssid :
and
wep :
you need that info to conenct
May 04, 2010 | 2wire (1000-000057-000) Modem
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
modem.
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I have a bigpond supplied 2wire wireless internet modem (2701HGV-W) which works seemlessly with my laptop running XP-sp2 for internet and email. Recently I purchased a Brother MFC 6890-CDW which offers...
Check if it's recognised on the local area network etc,make sure driver is installed and you may need to reset all pc,router etc to get connection.Now remember you need a router for this to work,with only a modem it will not function.You also need to restart all instruments etc before it's picked up by the router and the network..Google a bit and it will solve this.Make sure it uses wifi and not bluetooth as then it will need the right bluetooth connection to your pc..
Jul 27, 2009 | 2wire (1000-000057-000) Modem
I cant get my 2wire modem to connect to my
type 192.168.1.254 into your browser then click
Run System Setup wizard
Jul 18, 2009 | 2wire (1000-000057-000) Modem
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
I have just relocated property & Iam with Bigpond & have always been with bigpond & when I try to connect to the internet I get an I-primus pop up saying modem misconfigured - bad username or...
If you are using a usb dsl type modem and not a modem/router for connection, go into internet explorer>tools>internet options>connections tab, then look to see that Bigpond is selected as the default dial up.
If you are using a modem/ router which in effect is on all the time, go into the same menu in IE but tick the liitle button saying never dial a connection.
Sep 15, 2008 | Computers & Internet
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
2wire (1000-400108-001) Router Logo
467 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
