Missing windows xp config.exe
Have a HP Pavillion A620n that had a hard crash. Used the backup copies to reinstall all the software. Things worked well until it came to the Windows XP Home screen then a rectangle window came up saying that the Windows Config.exe was missing or corrupt and to try setup again. did this with the same results. Is there anyway to get the missing windows xp config exe so the backup copies will work?
  • 24 Answers
The problem is not with windows xp installation , just install updated antivirus and scan through.
Your system is infected.Go to start Click on run then type msconfig and press enter
Now in "System Configuration Utility" click on Startup option,and uncheck on the config.exe option.
best of luck.
Posted on Oct 31, 2008
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
I had an application called "creatacard gold 3" on my old computer with xp. I have all my important information from past 10 years is on that application. the computer crashed and i needed to buy a new...
The CreateACard Gold 3 (CAC Gold 3) will never work with Windows 7 64bit unassumingly because the software producing company has not upgraded their software for even Vista 64bit.
I recommend you to switch to " Hallmark Card Studio Special Edition" it has all the features of CAC Gold 3. You will enjoy it as there should be no problem installing it with Windows 7 64bit.
Good Luck!
Sep 21, 2010 | Computers & Internet
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
XP Crashed. Cannot Re-Install. Pls Help!
get and external hard drive casing, or if it is sata plug it into a normal pc, then backup the stuff and remove the virus, the do a coplete format, not the fast the one that takes long, it should fix you problem
Oct 22, 2009 | Microsoft Computers & Internet
Windows XP Missing configuration?
Sounds like you may have bad RAM. Try removing all of the RAM modules on your motherboard and put only one in the first slot. Start the computer and see if it works.
Jun 17, 2009 | HP L1706 17" LCD Monitor
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Dec 02, 2008 | Microsoft Windows XP Home Edition
Hp Pavillion restore problems
It Could be a bad stick of RAM I have seen a bad stick cause all kinds of problems.
Try booting with another stick of ram and see what happens.
Good Luck
wwiz
Oct 26, 2008 | Computers & Internet
Problem accessing windows xp home edition
Enter the BIOS at Startup
Press F5
Load Setup Defaults
Press Yes
Press F10
Save & Exit
Yes.
If you are getting a configuration error or if you have any message like code Purple configuration Error the you just need to call HP Tech Support and they will replace the motherboard Without any cost.
If you are in US you can call 1-800-474-6836.
Oct 26, 2008 | HP Computers & Internet
Windows xp home edition reinstall
If you use his disk, that will be better, because if it is original HP disk, it should install all original drivers at all, however this may delete all files on the computer depending on the type of installation you do.
Installing an older version of XP home does not make a big difference , as windows will update the system using automatic updates. What must be done, is ensuring that all proper drivers are installed.
Check device manager, in control panel/system, and see if all devices are installed with proper drivers.
Computers & Internet Logo
342 people viewed this question
David Payne
David Payne
