Question about Vacuums
The vacuum isn't picking anything up. Nothing is getting in the filter. Dirt is just being redistributed back onto the carpet.
  • daniellgwenn Oct 31, 2008
    My vacuum is doing the same thing...I took it apart cleaned all the hoses, replaced the belt and hepa filter still nothing. Please help it's only a year old and sadly I no longer have the receipt.
    Dirt Devil turbo vision
  • daniellgwenn Nov 04, 2008
    Sorry I forgot to specify what model it was ( I'm a dork)
    I have a Dirt Devil Turbo Vision. I bought it about a year ago but no longer have the receipt and don't know if it's worth bringing it in somewhere to have it fixed. Just to recap the prob it's just not sending any of the dirt into the canister. The suction is pretty much gone. And I've already replaced all the parts I can think of and giving it a good cleaning.
  • 566 Answers
Hi from uk if you could please verify what type of vac you have ? upright with dust bag? of dyson no bag? or is it a cylinder vac with flex hose? it would helpto advise on possible cause of vac not working and possible remedy ?
Posted on Oct 31, 2008
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Does not pick up
Hi There,
It may be that your belt is broken, or stretched out. This will cause the brushes to slow down dramatically when vacuuming the carpets. When the belt stretches, this causes the machine not to pick up on the carpets, and makes it seem that the vacuum is loosing suction.
In order to test this, turn the vacuum on it's side while it's on. Are the brushes spinning? If they aren't, this is because your belt is broken. If the brushes are spinning, the belt still may be stretched. Listen to the brushes as you put them onto the carpet. Can you hear a change in the sound like the brushes are slowing down? If you put just a little pressure on the top of the vacuum by stepping on it, do the brushes stop then?
It may also be the filter is clogged in the machine and needs to be replaced. Bagless vacuums use a HEPA filter in the dirt cup instead of a bag. With a bagged vacuum you just replace the bag when it gets full, but on a bagless vacuum the HEPA filter continually gets debris and fine dust accumulating on it, and needs to be cleaned, and replaced occasionally.
Here's a link to the owners manual for your vacuum. This will explain step by step on how to replace the belt, as well as servicing the filter.
http://www.dirtdevil.com/manuals/?id=83831cab-2807-439b-811d-52aab2fd84ee
If you still need some help, please just use the comment field here on Fixya to ask your question. I'm always more then happy to answer all follow up questions, and I really am not completely satisfied until you are able to fix your vacuum.
If you found this repair helpful, please be so kind and rate the repair, or leave feedback. This is greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Apr 23, 2010 | Dirt Devil Featherlite Bagless Vacuum...
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
The vacuum cleaner does not pick up anything from carpet. It does not even pick up pieces of thread laying on carpet. On tile floors it blows dirt away instead of picking it up. I've tried all the settings...
Sounds like there is a clog..
Usually its in the hose - look closely.. Stretch the hose out straight and look in there good..
Or a clog could be in the vac close to where the hose conects to the vac on either end..
This is most case scenario with these types of vacs..
I hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | Hoover U5269910 Bagless Upright Vacuum
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Dog hair from vacuum is being laid back onto carpet
my plush carpet and dog hair do not go together! I realized with this particular model and in my environment, the bag fills in one vacuuming! I literally dug out all the dirt I could by taking it apart and then changing the bag. Voila!
Mar 31, 2008 | Hoover WindTunnel Widepath U5397 Vacuum
Filter Queen, carpet attachment problem???
Open it up and see if the dirt inlet is clogged. It would be by the brush roll. But you must have a clog.
Mar 09, 2008 | Filter Queen Majestic Canister Vacuum
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
