Question about Aiwa F2400 24" TV
Aiwa F2400 TV turns off itself immediatly after turned on
My Aiwa F2400 TV turns off itself immediatly after turned on, need help! Thanks!
  • kentechie Jan 03, 2008
    I am having the same problem where the TV goes into "standby" mode after making some sounds like it's trying to fire up the image.
    Were you able to easily resolve the problem? I'd hate to throw out my TV.
    Sergeant:
  • 337 Answers
The safety circuit in the tv is sensing something is wrong and that is why it turn the tv off,it might be a regulator giving you more voltage that what he is supposed to give you.It should be a simple and inexpensive repair,get a qualified person to give you an estimate.
Posted on Sep 18, 2006
My zenith plasma tv turns off right after i turn it on
There are many reasons for this fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 07, 2015 | Zenith Z60PV220 60-inch Plasma TV
Aiwa tv a 219
Check this method.
Turn the television on.
Press the "Volume Down" button on the front of the TV and press the "7" button on the remote at the same time.
Enter in a new PIN code and new customer ID.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Check this link too.
Oct 30, 2012 | Aiwa F2400 24" TV
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Jan 27, 2011 | Aiwa TV-S2011 20"
No audio but power amp ic ok
replace the eprom chip
Feb 14, 2010 | Aiwa F2400 24" TV
The TV turns on and off after a few seconds and repeats itself.
Hi.
Either the stk convergence modules or the vertical ic have failed.
replace the 3 parts and it should fire up again.
Nov 21, 2008 | Samsung HCN653W 65" Rear Projection...
TV turns off by itself
you have a bad CRT causing the set to shut down. after the CRT has cooled down the computer finds all value to be ok then comes back on....
Jan 07, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Stereo Turns On By Itself
You must have the timer set. Press CLOCK/TIMER button repeatedly until the clock symbol or the word REC with the clock symbol disappears.
Nov 04, 2007 | Aiwa NSX-MTD9 Shelf System
Aiwa F2400 24" TV Logo
270 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
