Question about Fahrenheat Built-In Baseboard Thermostat Heater
Baseboard heater giving off burning smell
I just bought a house a couple of months ago and it has baseboard heaters. So far they all work just fine but the one in my sons room smells like its burning. We have cut it on more than once and tried let it heat for a while to see if maybe its just dust or something and the smell has not gone away. It sets off our smoke detectors. The heater itself looks brand new, and very well could be as the house was remodeled before we moved in. Is there anything I can do?
  • sandi gileo Oct 27, 2012
    Ironically, Years ago my base board heater had been smelling..just the usual dust thing I thought, and I hadn't used the one in that room for years. But a contractor was just here for other reasons and decided to take the front off the heater..and lo and behold a 'remote control' had fallen in there and pretty glued itself there..Hilarious to see...Thankfully he found it. Apparently things can fall in there!
I just ran into this same problem yesterday when I had a new baseboard heater installed in my tiny bedroom. When I turned it on it gave off a horrible smell that made me cough and choke. The stench went everywhere -- opening the bedroom windows and closing the door was not enough. I called the electrician this morning and he told me that it is the coating on the heater coil. He said they coat the coils when the heaters are manufactured to prevent them from corroding before they are installed. He said this would happen with any new baseboard heater I got. He suggested that I go stay somewhere else for a few days while leaving the heater on high to let the coating burn off. Since I could not do this, I had the heater removed again.
I wish I had a better answer for you. It seems crazy to me that a manufacturer would make heater coils out of a metal that corrodes easily -- I mean, it will start corroding as soon as the coating burns off, right? Plus, why use a toxic coating in the first place?
Posted on Nov 26, 2008
    Problem Solver:
I have this problem and my house is OLD. If there were a coating on the coils it would have killed my birds and given me asthma no doubt about it. I think its dust. If the problem isnt resolved get avacuum with an attachment that fits into the baeboard and dust it. If its a new baseboard write or go online and get a MSDS or whatever its called Its mareial safety data sheel MSDS. Every heater has one by law and if you cant get it from the mfg you should be able to get it online at msds.com or one of the other sites via search. The government mandates these esp if there are regisrterd coatings and if there aer coatings they should be registered. If there is soemthing like zinc or other harmful caoting you ought to be made aware and given an option to return them etc
Posted on Oct 30, 2011
I am interested in purchasing baseboard heaters, particularly I have been looking at the Farenheat PHH15002 baseboard heaters. I am purchasing an 1100 square foot 2 story condo with 2 bedrooms and a...
#1 you have to calculate the heatloss of your rooms,that will tell you ur wattage require. Oil filled or not,it's just as dry. As far as ur load to panel breakers, a rule of thumb is approx 3600 watts for 20 amps,using a number 12 wire. But ur wall heaterS should suffice
Apr 21, 2017 | Fahrenheat PHH15002 Oil Filled Baseboard...
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
Oct 26, 2010 | Electric TPI CORP TBS BASEBOARD HEATER...
What is the "oil like" smell in baseboard electric units? Do they use an oil in the assembling? Thank You
Hello KUNNES The smell should dissipate after the 1st couple of uses.They probbaly use some oil/protectant during assy.There should NEVER be any smoke.
Aug 18, 2010 | Fahrenheat Electric Hydronic Baseboard...
Burning Smell from Old Baseboard Heather All of a Sudden
If it was the first time started this season, then it was dust buildup burning off. If burning smell continues, call for service.
Dec 15, 2009 | Cadet Manufacturing 4F1000-8A Electric...
Chemical smell
Might be Plastic part is Melting due to Heating Element or a Burning Wire might cause Such Smell.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 10, 2009 | Fahrenheat Electric Hydronic Baseboard...
Cadet Thermostat
from the mod number it looks like you have electric baseboard. these do not have blowers in them they work off natural air movement. but heat up rather quickly. your gonna have to chk if baseboard is getting power to determine weather or not the t stat or the heater is not working. but first chk your circuit breakers. most heaters are 220v (double breaker)
Mar 19, 2009 | Cadet Manufacturing 6F1500W Baseboard...
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Fahrenheat Built-In Baseboard Thermostat Heater Logo
4,866 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
