Question about HP OfficeJet G85 All-In-One InkJet Printer
Printer won't eject paper correctly
Paper is not ejected after copying or printing. It prints fine, but the paper just drops onto the output tray and is not pushed forward, thus the next print page catches the end of the first and binds up or overprints. I know this is a mechanical problem but want to have some idea what it might be so I can decide if it is worth repairing. I have looked closely at the printer when it is printing out a page but can see no obvious problem - nothing looks broken or detached. I think someone may have tried to clear a paper jam by pulling the paper out the front of the machine. Could that have caused this kind of problem?
I just had the same issue yesterday. The problem was that 2 of the 3 paper seperators were broken. There should be 3 black plastic guides that point up and push the paper out before it drops down. They are clearly visible when looking from the front. Mine we eating the first page back into the paper tray. First page fine, 2nd page gets jammed.
Posted on Jul 05, 2008
  • 39 Answers
I would try to clean the rollers with a damp rag. I would also recommend a good 'dusting' with some canned air. Pulling the paper out is never a good idea... you can always hit cancel to release the paper. If this printer is used in an office, I would put a little reminder on it for others. Hope this helps!
Posted on Jun 24, 2008
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
It wont print at all and when it is the paper suddenly get all clogged up whyy and what can i do?
If your printer jams paper every time you try to print then there are two options, either the paper you use is wet (higher percentage of dew easily piles up if you have the paper boxed out for a while) or the paper is thin (usually the standard printer paper is 80 grams per square meter, if you use thinner paper it can get clogged because it can't get passed on from the intake rollers onto the ejection rollers.
The second option is that your printer's rolling mechanism is dirty/greasy. You'll need to open up the printer by lifting up the cover as when you're replacing the cartridges, and wipe the rollers with a dry cloth. You may need to do this several times before the rollers have enough friction to be able to pull the paper out and eject it onto the tray for printed paper.
Jan 15, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Error 6000 paper jam duplex
Sir,
1. Remove the paper tray.
2. Disconnect the power cord, wait 5 seconds, then plug it back in.
3. The printer will reset and eject the paper. if the paper does not eject, try to remove it manually.
4. Replace the paper tray.
5. Press the Print button on the printer to resume printing.
ThanksGood Luck
Aug 11, 2009 | Canon MX310 Office All-In-One Printer
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP laserjet 5500dn paper jam at fuser
I was able to fix my problem. On the left side of the fuser assembly there are two small plastic tabs or flags that move up & down. One is attached to the plastic rod/flap that you can see from the top of the fuser and moves when the paper comes out of the "chute". The other tab, which is below the first tab and moves when the paper has passed some point in the fuser, was broken off. I glued the tab back on and now the paper is ejected from the printer like it is suppose to.
I'm thinking that the broken tab was part of a page sensor flag that would tell the printer to stop rolling the fuser assembly when the paper was ejected. Without the flag, the sensor would disengage the fuser prematurely and stop ejecting the paper while the paper was still in the fuser.
Charlotte
Apr 17, 2009 | HP LaserJet 5500DN Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper Jam Error Message
I would try to clean the tires with alcohol, it's probably trying to pick up the other sheet but is slipping.
take out the tray and look inside for the pick-up and seperation tires.
Oct 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet G85 All-In-One InkJet Printer Logo
355 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
