Question about Dell OptiPlex GX110 PC Desktop
Swaping hdd hi i tryed to swap hard drives from my old computer with xp with one that has win98 my old computer has a pentium 2 the one with win98 has pentium3 why cant i get it to boot does not even go into windows help
    Master:
  • 397 Answers
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Posted on Oct 31, 2008
Have 2 dell inspiron 1525s, can I use the hdd from one in the other without having to reformat the good hdd
Swapping hard drives from one computer do not work because of hardware differences even between same brands and models.
You can install Windows XP on his computer but you need the Windows XP installation CD and you will need to use the product installation code from your computer. It is printed on the Windows label that is attached to the bottom of your laptop.
Mar 21, 2013 | Dell Inspiron 1525 Notebook
On bootup win xp does not read hard drive... even a known good one. "cant find OS" even though it detects the drive is there in F2 I have even been able to format the HD. My question is .... Is...
Sounds like it might be a motherboard issue BUT the best thing to do is to put a known good working hard drive in that computer and try installing Windows from the cd. If it can't install then the motherboard is bad more then likely. You can also try swapping out memory and trying it in different slots as well. If somebody tried flashing the BIOS and the computer got shut off by accident, that can screw up a BIOS and render the computer useless.
May 25, 2011 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Hi, I have a Seagate ST38421A HDD in an EMachines EOne PC, very old, Win98. When I turn on the PC it says there is no HD found in the system, and when I try to install Windows XP, it says it has no...
Sorry to say it it but your hard drive in your computer has stopes working. Best way to fix it is to buy a new hard drive for your computer or just buy a brand new computers.
Mar 04, 2011 | Seagate U4 8421 (ST38421A) Hard Drive
2 x 500Gb HDD's no longer recognised. IDE not SATA. They were recognised until 3 days ago. I swapped one for my 85Gb HDD that contained my operating system (XP) and neither has been recognised since. 80Gb...
Good day!
Did you try to use another IDE cables?If not,please find some IDEs there and try it.You can also use another PC and try the said HDD just to recognize it.or try to swap it in the IDE1. See if its work.
mastergani
Jul 06, 2010 | Western Digital My Book Essential Edition...
2 hard drives and 2 OS in one tower. win98 and winXP pro How can I configure so I have a boot option at startup?
Install first the Win98 OS to your Drive C: and then Install the WinXP to your drive D:
after you restart the system it will prompt you to boot either on Win98 or XP. You can also do this in one hdd only. all you have to do is to repartition the hdd
Mar 29, 2010 | Computers & Internet
Compaq Presario will not format Samsung 80GB hard drive.
Sir,
you are required to follow these steps below.
1 turn on your computer with HDD in it
2 Enter in to the BIOS by pressing F2 button
3 there entering in BIOS look for "Drive Configuration" it might be writen in some other words
4 there you will find ..."Hard drive SMART capacity" as enabled in box above.
5 Enter that box and Disable it.
6 Push F10 and reboot the machien.
Now you will be able to format , install etc on your hard drive hopefully
Oct 21, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
I have to recover fat32 partion with OS & data
Dear user,
Pl Check your format your c: drive or D: drive.
another way you connect your hard disk to another working coputer and pl check your hard drive data by drive.
Regards,
Ravindra Shah
Jun 01, 2009 | Computers & Internet
IBM NETVISTA P4 2.4G. no O.S.
If your old copy of win xp is not being used by any other computer then reformat the entire drive with xp. Also make sure that your drive is not divided into 2 or 3 sections. All updated will be available on the windows update site. The reason that I prefer tostart from scratch is Everything is new with no lingering Junk programs in the background. Need help email me at ddugard@cox.net
Apr 13, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Dell OptiPlex GX110 PC Desktop Logo
128 people viewed this question
Alun Cox
