Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Scanner won't scan
Trying to scan go throught the normal step press scan button change option press start and nothing happens scanner beam does not move but if you press copy then it will scan and then print the photo
what have i to do ??????????????
  • 102 Answers
Uninstall and reinstall
Posted on Oct 31, 2008
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
My scanner is not working. I press Scan, copy to file using the + arrow, then press Set. The window reads connecting to PC...but nothing more happens. Finally the copier/scanner resets.
Hello.
This issue happens because ether your network settings got changed around, or the router need to be reset , or the computer that is assigned this "Folder" that the scanner scans to needs to be rebooted or its sharing options has changed.
Let me know if you have some more information before I proceed with step by step fix.
First:
1. Reboot the computer where the scan folder is assigned to.
2. Reboot/reset the router or switch
3. Check your network settings and cable.
I will stand by with further information once you reply to me.
Thanks
Regards
ED Aka Rulds2008
Nov 18, 2010 | Brother DCP-7020 All-In-One Laser Printer
Scanner is not functioning
The Quick Start Guide might be leaving out a step. Get the Manual and try to follow it's steps, not the Quick Start Guide. Hope this helps.
Feb 25, 2010 | Canon PIXMA MP510 All-In-One InkJet...
I press scan but nothing happens I scan on cannon Mp 160 and I cant scan with my pc
Make sure the scanner is connected to your laptop/PC before you press 'scan' and is turned on.
Pressing the scan option will start Canan's software MP Navigator for scanning. You can also start MP Navigator on your PC and then start scanning directly from your program or from the printer button.
Dec 31, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I press Scan but nothing happens. How do I scan on Canon MP160?
Make sure the scanner is connected to your laptop/PC before you press 'scan'.
Scanner stopped functioning
r u already try reinstall your driver?if not, try it 1st and see the result..i'm afraid the driver is damages....try to download from canon support website in order to get the updated one...hopes it will help ; )
May 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
When pressing scanner to computer button nothing happens
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 2500 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
May 09, 2009 | Lexmark X2550 All-In-One Printer
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
Scanning
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=90792
Issue When the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Oct 04, 2008 | HP Officejet 4110 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
160 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
