I need a new Braun Supervolume Twist hairdryer because I like the long diffuser. Can I still get one please?
  • 2 more comments
  • jfischerpc Nov 15, 2008
    hi I need one as well because I love the diffuser and how well the twist dries my hair---any solutions? thanks, hannelore
  • andreacolby Mar 20, 2009
    i need to replace my braun supervolume haidryer too!...
    i had the silencio 1200, but its worn out now and i cant find a new one anywhere.i think the supervolume twist is the newer model of the same dryer-but i cant find one of them anywhere either. can anyone help?,,,
  • Anonymous May 06, 2009
    I need one too!!!...mine from the late 80's is almost dead!!! HELP!!!
  • trishpm84 May 11, 2009
    Why did they stop making this hair dryer. It is the best thing I have ever used. I bought 2 about 13 years ago. A man informed me that they were not going to be available in the US anymore. So he suggested I buy what I could afford. At that time it was 2. I did find the attachments at essentials.com Once I found those I bought 4, they are very inexpensive. About a week ago the dryers fried out. My hair does not style like it use to. They really need to bring that design back.
I have a brand new in the box Braun Supervolume Twist hairdryer available.
Contact me @ K9DDB@arrl.net for more info.
Thanks,
Jim
Posted on Jul 08, 2010
  • kelly4jesus0 Sep 11, 2010
    I need a new Braun Supervolume Twist hairdryer, do you still have one available?
  • fkerr17 Jun 25, 2011
    I join all the above in wishing for a Braun Supervolume Twist Hair Dryer. I have short hair and it has been a blessing to me. I am on my second one (have had it for many years) and am worried silly that it will "go" any day. Why not bring back a good thing???
My wife has had 2 Braun Silencios PSK 1200 B's for almost 30 years - Yes about 30 YEARS!!!! I take it apart and clean irregularly and in fact I have just given it a clean and a service today and it runs perfectly. But surely it must give up the ghost sooner (sadly) rather than later. There must be someone out there who has an old one they would be pleased to sell? Sorry I realise this is not an answer to the problem. However I guess that Braun would not reepeat manufacturing this product as surely there cannot be much profit in a hairdryer which could have an active life of up to (or more tha 30 years AND is used every single day without exception!!!! Tony
Posted on Jan 19, 2010
As long as the twist attachment is not broken you can use other Braun hairdryers with this. Just bring it to the store and find a dryer that fits. I have had mine for over ten years, and have changed the actual dryer three times. My problem now is that the spikes are falling out, two are missing and I am now very careful to keep the others intact.
Posted on Jul 14, 2010
When I changed Pentair Whiperflo motor with new Impeller & Diffuser seals the new motor shaft does not turn. Diffuser is pressing against Impellor not allowing it to rotate. What is wrong ?
Take the Diffuser off and run it if the impeller turns then might be tightening the Diffuser too much, it just needs to not move, doesnt really need a super waterproof seal or anything like that. If it still doesnt turn with the Diffuser off it might have locked up when replacing the Impeller, you can try to turn the impeller manually or remove the cover plate on the back of the moter and turn the shaft manually back there. OOoorr you broke it
Aug 03, 2015 | Pentair 2.0 Hp Whisperflo Pump
How to remove back
most diffusers are twist to remove, then lamp is also twist (Edison screw) - this is done from inside cavity, user accessable.
PS: righty tighty, lefty loosey.
Oct 18, 2013 | Dryers
HOW DO CHANGE THE BULB IN MY ELECTROLUX 3000 UPRIGHT VACUUM?
Remove the 5 phillips head screws on the bottom of the base.
Insert a flathead screwdriver into the square holes and release the latches.
Turn vacuum front up.
Lift back of powerhead cover and carefully remove.
Look at light diffuser carefully and remember how it fits. Lift off the light diffuser.
Push bulb in, twist, and remove.
Insert new bulb, push in, twist to lock.
Place diffuser over bulb.
Place front of cover on with the lip in the grooves on the inside of the base.
Settle cover into place, making sure the latches snap into place.
Turn vacuum over and replace screws.
Mar 11, 2011 | Electrolux Epic 3500 Vacuum
How do u change the liner in a lincoln mig welder
Hi:
That's an easy one. First unplug power cable and remove the gun from the machine.
a. Lay the gun and cable straight on a flat surface.
b. Remove and save the gas nozzle and nozzle insulator.
Make sure that the set screw in the gas diffuser
is backed out so as not to damage the liner.
Use the 5/64" (2.0 mm) Allen wrench provided with your new liner.
Remove and save the gas diffuser from the end of
the gun tube assembly. Remove and save the liner
nut from connector end.
c. Remove old liner and insert a new untrimmed liner
into the connector end of the cable. Be sure the new liner
it's appropriately for the wire size being used.
d. Before installing the gas diffuser, fully seat the liner
bushing in the connector end and install the liner nut
and finger tighten.
e. Be sure the cable is straight and then trim the liner (all new liners are over-sized and need to be cut to your gun lenght) 9/16" to 1" over sized to the length of your gun without the tip holder. Remove any burrs from the end of the liner.
f. Screw the gas diffuser (tip holder) onto the end of the gun tube
and tighten with the wrench provided.
g. Tighten the set screw in the side of the gas diffuser
against the cable liner using the Allen wrench provided.
h. Replace the nozzle insulator and gas nozzle.
That's it. If this was useful to you please vote.
Feb 23, 2011 | Welding Tools
How to disassemble philips 4891 hair dryer?
How to disassemble philips 4891 hair dryer? 'Conair corp ...
www.faqqq.com/fix/how-to-disassemble-philips-4891-hair-dryer-conair-co...
the of and to a in - Microsoft Research_??? ... w account security info april 99 right education comment net national co real ... say america feb maps canada ...
Philips - Hair Dryers
www.support.philips.com/.../worldproducts.jsp;...HAIRDRYERS...
PhilipsPhilips SalonPro AC Hairdryer HP4892 2000W IonBoost Ceramic diffuser ... PhilipsSalonDry Pro Hairdryer HP4891 2100 W IonBoost Ceramic diffuser.
How to repair the hair dryer not working not turn on - YouTube
? 1:02
https://www.youtube.com/watch?v=WITmaE5F9bI
Aug 16, 2012 - Uploaded by comohacerunomismo
This guide explains how to repair the hair dryer of our favourite brands: Phillips ... HOW TO FIX HAIR DRYERS / BLOW DRYERS, RESET AND ..
Dec 25, 2010 | Conair corp pers care 1875W CHR Hair Dryer...
How to take apart philips hp 4891 hairdryer
How to take apart philips hp 4891 hairdryer - Fixya
www.fixya.com/support/t6181177-apart_philips
Sep 27, 2010 - how to take apart philips hp 4891 hairdryer - Dryers question.
Hair Dryer Repair - iFixit
https://www.ifixit.com/Device/Hair_Dryer
iFixitHair Dryer troubleshooting, repair, and service manuals. ... I want to use hair drier without the heater element · Hair Dryer. 3 Answers ... Phillips #1 Screwdriver.
? 1:02
This guide explains how to repair the hair dryer of our favourite brands: Phillips Taurus Palson Braun Solac ...
Sep 27, 2010 | Dryers
Braun espresso machine replacement part
If you are unable to get the part directly from BRAUN by calling 1-800-272-8611 (if your machine still falls within the warranty they will usually replace it for free) then I would recommend that you try Ebay as corny as it sounds because you could likely buy a used/new set for not much more than you would pay for the "ordered part" from replacement part sites.
Here's an example: http://cgi.ebay.com/VINTAGE-BRAUN-Coffee-Cappuccino-Maker-MODEL-3062_W0QQitemZ110253282082QQihZ001QQcategoryZ38252QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Also, if Braun no longer carries the part you need you could also try asking them if they have a diffuser from a different model that would work with your machine.
Good Luck!
May 19, 2008 | Coffee Makers & Espresso Machines
call www.smallappliance.com They stock many parts not on their site.
Sep 03, 2007 | Braun Tassimo Espresso Machine/Coffee...
Computers & Internet Logo
1,256 people viewed this question
David Payne
David Payne
