Question about Tricity Bendix AW1000W Front Load Washer
Drum sticking Drum won't turn smoothly sounds like something stuck or sticking. Is there any way to get in to see if something is stuck? If it isn't that what else could it be? I took off the seal at the front to see if you could gain access. Also took off top cover and back cover. Made sure thefilter wasn't blocked. Daughter heard the washer as it was finishing it's wash and said it was making a whirring noise. There appeared to be a sock stuck so she thought the washer was trying to get the sock out. The sock had disappeared when took washing out. Can't find how to see where it has gone.
  • 38 Answers
Take the heater out it will be stuck round that or wraped round the front of the drum u may be able to get @ it if not im afraid u will have to split the drum to get it out if u r not an enginer i would not attempt it good luck
Posted on Jun 26, 2007
I have LG 6kg WP9032 machine. When i operate drier a peculiar sound is coming. Looks like something is stuck underneath the drier.How
Stuck under where ??? Between the drum and the housing inside ? Many times underwires from bras that come loose will get caught between the drum and make a squealing/squeaky noise.. look inside along the edges of the drum and see if you can see anything unusual sticking out..sometimes rotating the drum manually helps find it.
Jan 23, 2018 | LG Washing Machines
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
My dryer drum is stuck. When I open the top, the drum is set so that I cannot get my clothes out. I looked at the directions to push a button in on the inside, and then manually rotate it. I had to...
It sounds like one or both of the bearings have failed. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Aug 12, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I replaced a drive belt on my Amana model ALW480DAWabout a month ago. A couple of days ago it got stuck again and starting amoking but I stopped it before it broke and was able to spin the water out. Any...
Sounds like drum pulley / drum is sticking could be sock in drum, Can you turn it by hand , is it noisy...The drum sticks and motor keeps driving which burns out the belt..Hope that helps you...
Oct 01, 2009 | Washing Machines
DRUM MAKES NOISE WHEN TURNING ALMOST LIKE IT'S RUBBING AGAINST SOMETHING INSIDE THE MACHINE. SOUNDS LIKE DRUM IS TRYING TO STICK AT SOME POINT OF ROTATION.
check that all the support springs are connected and one is not broken. It is also possible that something is between the drum and the frame.
Sep 26, 2009 | Dryers
My WD440 has trown its drive belt and something
hi
it sounds like there is a sock or something simular stuck between the drum and tank,the paddle is removable which may help you hook out the item,if you grab the drum paddle from the rear and pull it towards you it will then lift up,once you have removed the offending item,you just line up the slots on the drum with the pegs on the paddle and push towards the rear of the machine and you will here a click,this means the paddle is secure.
Aug 02, 2009 | Hotpoint Aquarius WD63 Front Load...
Sticking drum
YOUR DRUM BEARING HAS GONE
Aug 02, 2006 | Hotpoint WMA30 Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
234 people viewed this question
Top Tricity Bendix Washing Machines Experts
Bobby G
Bobby G
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
