Question about Frigidaire FEF352 Electric Kitchen Range
Self cleaning lock
My husband hit the self cleaning button and the lock engaged so being the man he is he tried to fix it himself.Now the door is locked to and the light is still flashing.I held the cancel button for 10 seconds but that didn't help.Please advise me on what to do.pictoria1@aol.com
  • pictoria1 Oct 31, 2008
    Thank You, Thank You, Thank You. Thank You , I'm so relieved.
  • 1,031 Answers
A) Grabbing the handle, push the door in (like you are trying to force the thing all the way to the garage through the wall).
b) While doing this, hold down the clear/off button until the "door lock" light starts to blink like you are choking off the electricity that keeps it lit.
c) (This is the tricky part) Repeat step 2 - I mean "b" - until you really have killed the light, and the appliance gives off an audible clicking sound, signifying that it has been rendered open-able again.
Now you can open the door and .hope this helps
Posted on Oct 31, 2008
Door locked wont self clean
Turn off breaker for minute or so if no contact repair man mcro switch bad or out of position. Did he try to pull door right after candle. The motor takes time to clear the hook from the latch. If so he probly bent some thing in the mech that latches the door or on the switch plate that holds the micro switch
Apr 25, 2017 | DCS (WOTD-227) Double Oven
Door lock engaged with door open
push the clear/off button for about 3-5 seconds this should release the latch
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do I self clean my gallery series fridgidaire?
Some of the self cleaning ranges require that the door be locked before the self-cleaning cycle will work. If your oven door has a manual locking lever then make sure it is completely latchedthen press the self-clean button. Also make sure the dooris completely closed because if there is not a manual latch then it will be a auto latching system. If not then there could be a problem with the button on the control panel for the self cleaning option.
Jan 14, 2010 | Kitchen Ranges
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
I did not follow directions on self-cleaning and now stove is loc
Since the door is open and the lock is engaged, you will need to hold the "door closed" switch in located in the top left door opening. Push and hold the switch in, push the clean button, set the time at 3:00 hours, keep holding the switch in for 20 seconds, then push cancel button. The motorized locking mechanism should disengage. Then, you can release the switch. Hope this helps.
Dec 06, 2008 | Frigidaire FEF352 Electric Kitchen Range
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FEF352 Electric Kitchen Range Logo
71 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
