Question about Toshiba Satellite A205-S4617 Notebook
Toshiba A205 full screen
I tried resolution but can't get it to full screen the best is to change to 125 or 150 percent there has to be easier way
  • Toshiba Master
  • 4,806 Answers
Go to the display settings in the control panel and change the resoloution to 1024x768 pixels, save and that should do the trick
Posted on Nov 13, 2008
Toshiba TV - no full screen
You need to go to the control panel in your computer and change the display resolution. The two resolutions are not matched is the only problem here. Find out what the native resolution is of your tv and match it in your computer.
Jan 27, 2014 | Toshiba Televison & Video
Toshiba satellite monitor is scrambled, how to fix?
Check to see if the problem is the screen Inverter, or the graphics chipset, or the LCD screen.
Use an external monitor as a test.
If the screen of the external monitor shows a scrambled display you have a problem with the graphics chipset.
If the screen of the external monitor does Not show a scrambled display, you have a problem with the screen Inverter, or the LCD screen.
90 PERCENT of the time the fault is the screen Inverter.
External Monitor;
1) You can use a CRT monitor, (Looks like a small TV), as a VGA monitor,
Or
2) You can use a flat LCD screen monitor that has a VGA cable.
A) Laptop OFF, and monitor OFF, attach the VGA cable from the External monitor, to the VGA port on the Toshiba Satellite A205 series Notebook PC.
This is an example of a VGA cable, and it's connector, and a VGA connector on the laptop,
http://en.wikipedia.org/wiki/VGA_connector
B) Turn the monitor on. If it is a CRT style let it 'warm up'.
Turn the laptop on.
C) The display is supposed to automatically show up on the external monitor.
If it does not, press, and hold down on the Fn key, and also press the F5 key.
Still no?
Holding the Fn key down, tap the F5 key again.
Display good on external monitor? Problem lies with the screen Inverter, or the LCD screen.
Either OR.
Primer:
An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (screen Inverter) is used to convert the electricity provided by the laptop, for the LCD screen, and Backlight.
As previously stated, 90 PERCENT of the time the fault is the Inverter.
Laptop open looking at the display assembly, the plastic thin frame in front of the LCD screen, and surrounds the LCD screen, is the Display Bezel. (Resembles a picture frame)
The Display Bezel is removed to access the screen Inverter.
The Inverter is right behind the Display Bezel, and located at the bottom area of the LCD screen.
The Display Assembly has to be removed from the laptop, to remove the Display Bezel.
Toshiba's term for the Display Bezel is Display Mask.
The Toshiba Satellite A205-S5804 Notebook PC is one of the Satellite A205 series of Notebook PC's.
This is a link to a free Service Manual for a the Satellite A205 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Scroll down to the second Satellite heading. The one that begins with Satellite A10.
Scroll across, and click on A200.
After you click on A200 it may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 146.
4.10 Display Assembly
Page 151 shows how to remove the Display Mask.
4.11 Display Mask
Page 153 deals with the screen Inverter.
4.12 FL Inverter Board
Takes a really sensitive (Read fairly expensive) multimeter to test an Inverter.
Due to the low price, and ease of replacing, the screen Inverter is replaced to test whether the old one is bad.
Example of a screen Inverter (FL Inverter Board) for a Satellite A205-S5804 Notebook PC,
http://www.batterysupport.com/toshiba-satellite-a205-s5804-inverter-p-216526.html
Compare to the price of a replacement LCD screen,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A205-S5804/
To summarize so far;
1) Display shows good on external monitor. Replace screen Inverter. Still the same problem? Replace the LCD screen.
2) Display on external monitor is scrambled also?
Fault lies with the graphics chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The GPU for a Toshiba Satellite A205-S5804 Notebook PC (Part Number PSAF3U-0NR00V), is an Intel (Mobile) GL960 Express,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipsets
It is soldered directly to the motherboard, therefore it is Integrated Graphics.
{Integrated Graphics is also known as OnBoard graphics.
ON the motherBOARD.
The GPU is soldered to the motherboard.
In comparison if the GPU were soldered to a removable adapter card, it would be a graphics card, and Not integrated graphics }
This means if the graphics chipset is found to be bad, motherboard replacement is the solution.
{ Disassembly guide,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm }
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 05, 2011 | Toshiba Satellite A205-S5804 Notebook
When I play games on my laptop it is not full screen which is hard when playing seek and find games
Some games require a different screen resolution for best results, try changing your screen resolution and see if it helps....
Jul 16, 2011 | Toshiba Computers & Internet
I want to know how to make the page type (font size) bigger so I can read the pages i browse easier to read. Print on the pages are to same. thank you
right click anywhere on desktop>properties and set the screen resolution to a smaller value.
To change your monitor's resolution
1.
Right-click the desktop, and then click Properties.
2.
In the Display Properties dialog box, click the Settings tab.
3.
Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller.
4.
Click Apply to have the new resolution take effect.
5.
If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution.
6.
Click OK.
Microsoft Windows XP changes the resolution to the settings you chose.
Jan 14, 2011 | Toshiba Satellite L500 Series Notebook
Connect TOSHIBA SATELLITE A205-S5855 Laptop to TOSHIBA 40H80 TV
You can use the VGA cable which has 15 pins at both ends. For sound, you will need mini stereo phone plug at both ends.
You will have to use the combo key Fn and either F5, 6, or 7 to select the internal, external, both.
Make sure to set the video resolution to the native resolution of this TV otherwise you will get 'Format nor supported' on the screen.
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Gateway FPD2275W LCD Monitor
I intalled windows in my lap top and it oppened a 80% screen only you know why?
Two thing can cause this problem.
1. The screen resolution is set too low. Try changing the screen resolution to 1024X768
2. If you cannot alter the screen resolution then the video driver was not installed or the wrong viseo driver was installed.
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Oct 30, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite 17" L355-S7812 Gaming Resolution Problem
This is a common problem with Toshiba Notebooks. Their driver is locked onto Intel version 13.29 which is a buggy driver that has an issue keeping the aspect ratio settings in the control panel. You will want to download Intel's 15.9 drivers (the zip file for developers) and force that driver to install on the notebook by manually installing the driver in the device manager.
Another fix is to enable hot keys in the intel graphics control panel and press control , shift , f11 when the game starts to change the aspect ratios of the screen.
Its annoying yes and I wish i would have known about this myself before purchasing a toshiba sattlelite.
Jun 05, 2008 | Computers & Internet
My games do not display full screen on my toshiba l355
Have you tried changing your resolution? The games should have a recommended resolution in their instruction booklet. Try running your computer at that resolution, and you should get full screen.
May 05, 2008 | Computers & Internet
Toshiba Satellite A205-S4617 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
