Question about Pioneer PureVision PDP-50MXE1V-BNC 50 in. Plasma Television
'buttons & ir lock' display for a PDP-50MXE20
Hi, I can't access the menu on my plasma.
I get codes such as 'buttons & ir lock' , 'memory lock' and 'buttons & ir lock' display for a PDP-50MXE2O.
i think I need a way of resetting or unlocking the locks.. can you help me?
cheers Craig
  • Anonymous Mar 02, 2009
    I have exactly the same problem!
    Cheers,
    Nolls Noyce
  • Anonymous Apr 25, 2009
    I can't control my PDP-50 with Remote Control, message IR LOCK appears on pressing any button.
4 Suggested Answers
  • 4 Answers
SOURCE: Will the Pioneer PDP-R03E Plasma TV Media box work
Yes it will
Posted on Jan 14, 2010
BElectric
  • 1140 Answers
SOURCE: My Pioneer 50MXE20 panel comes
On the narrow underside on the left side of your TV, there is be a very small round button between the "MENU" and "DISPLAY/SET" buttons:
This is the "FUNCTIONAL LOCK" button. If you press this button repeatedly, your TV will cycle through various lock options and "OFF". The current option will be displayed on the screen.
Press this button repeatedly until "OFF" displays on the TV screen.
Please let me know if you need any further assistance.
Regards,
BElectric.
Posted on Jan 06, 2011
eagle338
  • 4889 Answers
SOURCE: Is my Pioneer 50" plasma PDP-503HDE HD ready?
Yes it is but upto 720P only. It is not full HD(1080P).
Posted on Jan 10, 2011
Where do I buy IR Sensor for Pioneer plasma TV PDP-4214. I don't have part number and I live in Alhambra, outside of Los Angeles.
You will only be able to buy the entire board from Pioneer in Long Beach, if it's still available. If not, I may be able to repair the board to the component level. If you need a repair, please contact me through my website at audioserviceclinic.com. I used to work for Pioneer,
Mar 18, 2013 | Pioneer Pdp-4214hd Tv Main Analog Board...
Problem with picture on HP Plasma TV
hello!
This is known problem with PDP displays. That means: one of X-buffers has bad connection to the PDP(plasma display). Or, in some cases, depend on PDP type, it could be panel itself at fault. You need to open your set carefully and get an access to X-buffers. Usually, at the very bottom of PDP, covered with aluminum heat sinks. By turning set on, while face down, start tapping slightly with isolated handle of medium size screwdriver. Observe, when line(s) vanished. That's where connection(ribbon cable) between PDP and X-buffer is compromised.
In some PDPs, those integrated into panel itself and nothing you can do, except to live with that or replace panel. Hope, you end up just reconnecting ribbons. Anyway, you must have very good technician background to do so.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
TV won't take remote control commands
I have the same issue. Obvious thing is to install new batteries. I assume you have done this already. Have you tried using the buttons on the bottom of the monitor to scroll through the main menu using the volume buttons to option 3, and scroll down to IR remote to see if it is selected ON. If it is OFF, select ON with the bottom LEFT or RIGHT buttons.If your remote still does not work, you can try to work it by connecting a 1/8" stereo mini-plug cable into the front end of the remote and the other end to the monitor remote control jack(second from bottom on back panel). Check the IR Remote settings this way. If it still does not work then you have the exact same problem I have... IR and Wired remote inoperative. I am still hoping for a solution but I am afraid there is either a stuck bit in the IR remote circuit or a bad board/chip. Anyone have a solution to this??
OPTION3
KEY LOCK OFF←→ON
IR REMOTE OFF←→ON
LOOP OUT OFF←→ON
ID NUMBER ALL←→1←…→256
Nov 08, 2009 | Pioneer PureVision PDP-424MV 42 in. Plasma...
Panel locked
Remote needed:
When Panel Lock is set to ON, the buttons (SOURCE, MENU, VOLUME, SELECT, MUTE, POWER) on
the front of the PDP will not operate. However, these buttons will operate when setting Key Lock OFF.
1 Press the Menu button. Move the joystick up or
down to select “SETUP”, then press the joystick
to enter.
2 Move the joystick up or down to select “Panel
Lock”, then move the joystick left or right to select
“On” or “Off”.
3 Press the Menu button to exit.
Jun 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Lock access code
Just follow the steps carefully and you should be up and running again. Thanks for the model number.
1) To reset/change the SMART LOCK code, follow these steps.
Press the MENU button on the remote to display the on-screen menu.
Press the Cursor Up (also known as CH + button, above menu button) or Cursor Down (CH - below the menu button) to highlight SMART LOCK. Then press the Cursor Right (VOL + button to right of menu button) to display the SmartLock ACCESS CODE screen.
Using the numbers on the remote keypad, enter 0 7 1 1. " INCORRECT CODE" will appear on the screen. Enter the code 0 7 1 1 again.
Cursor Down to CHANGE CODE and enter 0 7 1 1 and then CONFIRM CODE and enter 0 7 1 1.
Press the STATUS / EXIT button (left of CH +) to save the new code in memory.
2) If the grandkids have locked out any channels, then you will have to perform the following steps:
Press MENU, highlight SMART LOCK, right arrow, enter 0 7 1 1, confirm by entering 0 7 1 1 again.
Cursor to BLOCKING OPTIONS, right arrow, and highlight CLEAR ALL, right arrow.
You should then see CHANNEL....ALL, LOCK....YES, ALL UNLOCKED.
3) To turn SMART LOCK off, follow these steps.
Cursor to BLOCKING OPTIONS, right arrow, and highlight BLOCKING OPTIONS, right arrow,
Aug 19, 2008 | Hitachi 51F500 51" Rear Projection...
PC connection
Hi, Im having similar problems my new laptop runs on vista and wont display on tc, also tv menu blanks out pc mode & PIP not displayed. Temporary qick fix is to set uo older laptop xp to tv wait for the desktop screen to appear the swith then cable from the old laptop to the new on - like a boost. doing that allows me to have the laptop display on my tv and allow me to access menu, PC & PIP
Feb 07, 2008 | Samsung HP-P5091 50 in. Plasma Television
Screen menu displays locked & unlocked
possible faulty VGA Controller board.
Dec 03, 2007 | Gateway FPD2275W LCD Monitor
Pioneer PureVision PDP-50MXE1V-BNC 50 in. Plasma Television Logo
225 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
