Question about Dell Dimension 3000 PC Desktop
Video card not working, monitor goes off
Windows logo comes on, then screen goes dark. Video output on the pc was broken, so I installed a pci expansion slot video card.
Do I need to change bios? Start in safe mode?
  • Seth100 Nov 03, 2008
    Here is what I did:
    1. Checked the BIOS setting and made sure it was PCI
    2. Loaded the card drivers (CD came with card) in safe mode
    3. Disabled (do not delete) the integrated (motherboard) video in Device Manger...ya can't have them both on!!
    Scholar:
  • 32 Answers
     In the bios there could be setting to disable your onboard video. Since the output was broken, see if there is an option to disable the onboard setting. If you do this and you are still having problems, I would go ahead and start in safe mode, then lower your resulution to the lowest settings till you can get the video drivers loaded for the new card that you have just bought.
        Joe < Data Miner >
Posted on Nov 01, 2008
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
Problem installation video card
Hello Virna, i have that exact graphics card and dell GX270 desktop here at home, tho it has been awhile since i removed the Nvidia PCI card for a more favorable AGP card. From what i remember, first check your BIOS (hit F2 on startup) and select integrated devices, scroll down and make sure your default video output is either PCI (if available) or AUTO) exit saving changes. If that yields no result. Plug in a second monitor to your old integrated video output, if you can view windows after bootup from there, then you can install the proper Nvidia display driver for windows Xp (available here: http://www.nvidia.com/object/winxp_175.19_whql.html ). After installing, right click on the desktop, select properties, display settings tab, and make sure the Geforce card is the main monitor and the desktop monitor. Click apply, unplug the integrated VGA output, and restart. Hope this helps.
Apr 03, 2009 | Evga nVIDIA GeForce FX5500 Video Card,...
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
Monitor doesn't work
Sounds like a bad video adapter. I'm assuming your emachines has an integrated video adapter. Put in a video card (with the power plug pulled out! Touch the bare metal frame of the computer with your hand before inserting the video card into the agp or pci slot Don't touch the motherboard). If you get video, you may or may not need to install drivers after that. XP has a lot of video drivers, but lacks quite a few of them, too.
Jul 30, 2008 | E-Machines eMachines Desktop PC
Will come on-then say no signal
If you mean the monitor is fine during the Windows booting process and then just as your about to go into Windows goes black then do this...
Start the computer
When the bios screen goes start pressing F8
A Windows Startup screen will appear
If you see the Windows Logo (the loading one) then hit reset and try again
At the Windows Startup page, select Safe Mode and press enter twice.
Windows will now load. Go into Device Manager (Start-Settings-Control Panel-System-Device Manager)
Select the video card, and uninstall it.
Restart Windows
Reinstall your video card using the Installer package (if it's ATI or nVidia)
If this dosn't work, then post back and we will try something else
Apr 16, 2008 | Gateway FPD2275W LCD Monitor
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
Dell Dimension 3000 PC Desktop Logo
104 people viewed this question
Alun Cox
