Question about Sony Cyber-Shot DSC-T5 Digital Camera
Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
Getting Error "C:13:01 Format Error" on LCD display when inserted Memory Stick PRO Duo card.Before this Error, I was getting "C:13:01 Re-insert the memory stick" and this was disappeared when I tried to reinsert the Memory stick 20 -30 times. Then I am getting this "C:13:01 Format Error".Internal memory(32MB) is working fine.When I took this to Sony service centre, I was told that this problem cannot be fixed, need to replace the entire circuit board which will be costing almost a new camera.Please help to resolve this issue.
  • Joe Hawthorn
    Joe Hawthorn Dec 19, 2008
    Same problem after some time useage. Another memory stick works fine.
  • Anonymous Jan 22, 2009
    me da error c:13:01 lo he intentado leer por todos los medios posibles, pero no me reconoce la targeta, siempre dice inserte memory stick, lo he probado con todo. Que puedo hacer?
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Posted on Jun 17, 2010
The problem is basically the memory stick (MS) having loose contact with the camera's internal memory connectors either due to worn out MS plastic casing (making it thinner) or connector wear. The objective then would be to make the MS contacts closer/press against the internal camera connectors. An everyday scotch tape (perhaps a layer or 2) on top of the label side of the connector should do the trick. Just make sure the tape is thick enough, properly trimmed on all edges and sticky enough to avoid problems while inserting/removing the MS. Too thick would give you problems pulling out the MS so be careful. Hope this helps
Posted on Dec 03, 2008
  • EngrCool Dec 03, 2008
    correction "on top of the label side of the connector should do the trick" should be "on top of the label side of the MS should do the trick"
I have been told that it is a dirty or bent connector inside the internal card reader. I think your service person would rather charge you for a full board than just clean or straighten the connector. Or he will just clean it and charge you for a board.
Posted on May 14, 2009
Have you tried formatting it??
Posted on Feb 03, 2011
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
I want to download photos from memory stick pro duo of sony company
Use card reader and insert your cams stick pro duo memory card/chip into it. Then insert card reader into Pc usb and copy your photos from memory stick pro to your pc.
Aug 19, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Sony dsc-s730 format error
Download the pics to your computer using a separate memory card reader. Then, format the card in the camera.
Sep 22, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
C:13:01 Format error
don't worry.i got the solve this problem.because all this happened due to the old files on memory card which corrupted automatically.so you need to format the memory card.then insert the memory card on digital camera.your camera will work finely.
Nov 06, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony memory stick pro duo format error
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
Jun 12, 2008 | Sony Cyber-Shot DSC-S75 Digital Camera
Format error
Format memory stick, if no data on it.
If there is data on memory stick, copy it on PC using any good card reader.
May 31, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Sony cyber-shot DSC-S700
maybe you have to format it on the computer
Jan 18, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sony Cyber-Shot DSC-T5 Digital Camera Logo
5,803 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
