Question about SanDisk Sansa E280 MP3 Player
Sansa e280 fatal failure - black screen, unrecognized by comp, won't restart..
Hi.
The problem seems to be software, because it hasn't suffered any physical damage. Everything worked well for about a year, then I tried managing files using Winamp, and when I disconnected from the computer, The black screen appeared. Since then I can not operate, or connect to the computer to try and fix the problem.
Please Help!!
  • eladmor1 Nov 01, 2008
    First of all, thanks for the help..
    I managed to connect to computer - but it doesn't recognize the e280.
    can you please tell me what to do?
    where can I download the needed firmware? ( or the device operating system)
  • melaniekry Nov 06, 2008
    My sansa MP3 PLayer doesn't switch on anymore. It used to work perfectly fine, when I tried to switch it on again it doesn't react at all. Can't connect it to the computer either. Please help!
  • 758 Answers
1. turn sansa clip on
2. slide to "hold"
3. press and hold center button do NOT let go...
4. plug in the connector cable
5. wait until computer recognises Sansa device
6. let go of center button
7. drag n drop files and you are all set
if that doesnt work you will need to go to the sandisk website to update the firmware on your device..
let me know if you anymore questions..
Please rate accordingly
Thank you
Computerrep
Posted on Oct 31, 2008
My sansa will turn on but my screen is still black
There is a reset button on the player which can be pressed with a offfice pin to clear up the hanging condition.
If the screen does not turn on even after the reset is done , the fault can be failure of the hardware in the Ipod.
Oct 28, 2010 | SanDisk Sansa E280 MP3 Player
Need software to download videos and pictures
Hey!
Kindly follow the instruction here, to get all the software needed...
Regards,
Pelu.
Sep 01, 2010 | SanDisk Sansa E280 MP3 Player
Mp3 turns off/on wont charge
one of my friends had the same problem
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
I hope my post was helpful let me know!!!!
Mar 10, 2009 | SanDisk Sansa E280 MP3 Player
Sansa e280 goes to glitch screen after trying to refresh database
if the bar in the middle of the window has stripes its normal and it will keep doing it no-mater wat you do
Oct 26, 2008 | SanDisk Sansa E280 MP3 Player
Sansa problems!!!
i recommend that you open it up and see if any connections are loose
May 07, 2008 | SanDisk Sansa E280 MP3 Player
Cracked screen e280
My best advice is to get a junk player from ebay or other source,one that has a good screen. There are only 4 screws that hold the screen on,once you remove the back. With a small phillips screwdriver and about 10 minutes you can replace the screen.
Apr 25, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 not responding
I would suggest holding the 'power' button down for a good 15-20 seconds.
Apr 08, 2008 | SanDisk Sansa E280 MP3 Player
Cant get songs onto my Sansa e280 player =[
"Refresh database" is a normal message that you will get everytime you unplug the Sansa from the computer - don't worry about that aspect.
If the songs that you have transferred have DRM encryption on them, they may not play right (or at all) on the Sansa.
If you have Windows Media Player 11, I would get the firmware update from the Sansa website AND format the Sansa inside Windows Media Player:
for the firmware,
for the format, http://www.sandisk.com/Retail/DriverDownloads.aspx
Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything and get your player functioning normally.
-Tha Mp3 Doctor
Mar 18, 2008 | SanDisk Sansa E280 MP3 Player
Restart sansa e280
Try this: Press and hold the center button and the start button at the same time for about 10-20 sec. it worked for, plus thats what the ppl at sandisk told me to do.
Feb 13, 2008 | SanDisk Sansa e250 MP3 Player
E280 and my computer do not connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 03, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
159 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
