Question about Malber P21 Front Load Washer
My washing machine won't fill with water
I just purchased the Malber P21 and had the company install it for me. When I tried to start the machine, nothing happened. I checked to make sure water was coming out of the faucets, and it was. What is the next step?
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Posted on Aug 22, 2007
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email INFO@MALBERAPPLIANCE.COM.
Oct 17, 2014 | Malber P21 Front Load Washer
My washer will fill with water but it will not rotate
the clicking of your machine is the drum rotation clockwise /anti clockwise the main problem is most likely the motor brushes worn depending on make of machine to how to remove and replace
May 12, 2012 | Malber P21 Front Load Washer
My malber washing machine p21 will not turn on it is making a clicking sound but nothing else
It might be due to the switch problem or wire will be cutted for that which runs the engine... Check the wiring and switch on the machine..
Thanks
Apr 01, 2012 | Malber P21 Front Load Washer
It started leaking when filling with water...why?
I've had to replace the internal hose three times where the water connections are. It is a "Y" hose, that is not sturdy, and a defective design. I've had this washer for three years, and this keeps happening. If you look carfuilly, you'll find a hole at the "Y" junction.
Feb 22, 2010 | Malber P21 Front Load Washer
I have a used malber p18. all the hoses are
Ok. Assuming that the water is turned on, and the electricity is ok it should fill, if not check is machine dead or able to function in other ways if alls ok then replace the solonoid valves that allow water to enter..Hope this helps.
Nov 27, 2009 | Malber P21 Front Load Washer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Door handle
Malber...hmmm..sounds like a european make, right? only way to find that is perhaps accessories at website?
Mar 11, 2008 | Malber P21 Front Load Washer
Bleach/fabric softener compartment
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Sep 06, 2007 | Malber P21 Front Load Washer
Water level not right
There is a water level switch on the machine. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you should find it easily. You can either clear any obstruction in the tube or replace the water-level switch (easy to do it). Good luck !
May 19, 2006 | Malber P21 Front Load Washer
Malber P21 Front Load Washer Logo
139 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
