Question about HP PSC 1210 All-In-One InkJet Printer
Hp 1210 all in one printer
Run time error mfiles\Hewlett Pacard\Digital Imaging\bin\Hpqdirec.exe
  • Anonymous Dec 30, 2008
    computer does not recognize the printer but sais it is installed
    hp1210psc
    President:
  • 2,712 Answers
You will need to uninstall, reboot PC and reinstall the software.
Posted on Oct 31, 2008
After installing teh FULL PSC 1410 all in one printer the "solution center" software is not installed. With the same driver when I installed previously it was there but after i format my computer...
you can locate the solution center program in the folder
C:\Program Files\HP\Digital Imaging\bin\Hpqdirec.exe
open an explorer window, paste C:\Program Files\HP\Digital Imaging\bin into the address bar, find Hpqdirec.exe, hold alt, click and then drag to the desktop.
Click on the newly created shortcut, press F2 then rename it to HP Solution Center.
Aug 27, 2011 | HP PSC 1410 All-In-One InkJet Printer
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
No longer have HP Director to control my scan/prints
It's most likely located somewhere around "C:\Program Files\HP\Digital Imaging\" and look for hpqdirec.exe
Nov 18, 2008 | HP PSC 1210 All-In-One InkJet Printer
This error will not stop coming up on my computer
Navigate to C:\Program Files\HP\Digital Imaging\bin
or C:\Program Files\Hewlett-Packard\Digital Imaging\bin
Double Left Click on the executable file:
hpqdstcp.exe
You will NOT see anything happen but it will get your program destinations setup correctly and hopefully remove the error. This sometimes happens when you change printers and old stuff stays on your PC.
Hope this helps.
Nov 04, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP Solution Center cannot detect my 6110 AIO
Hello Buzzland, this error usually occurs when the HP Digital Imaging monitor is not running in the background. HP digital Imaging monitor is a service that invokes the other services when required. If this service is not running, you may not be able to open the HP Solution Center.
You can usually find the icon of HP Digital Imaging Monitor in the systray. To check if the HP Digital Imaging Monitor service is running, open the task manager , and in the process tab, search for the file called "HPQTRA08.exe" . If it is not present , navigate to C:\Program Files\HP\Digital Imaging\Bin\ (assuming that your system drive is c: and the folder maybe HP or Hewlett Packard) and search for an application file named hpqtra08.exe. and double click it. The application will start running in the background. Sometimes it may also happen that you have unchecked some startup programs from the micosoft system configuration utility (msconfig) and this file (hpqtra08.exe) is also included in them. If so, you must check the application to run it on startup. Now , restart the system and open the HP Solution center. If it works, fine. If it does not work out , open "services.msc" from the command prompt and search for the service called "HPZPML" . If it is found, make sure it is started. (Set startup type = automatically). Restart the system and try opening the solution center.
Still if the issue persists uninstall the complete entire software and reinstall it. This will probably work in case all of ther others fail.
Sep 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp 1210 all in one printer - error message
Two problems;
1 - This unit cannot be set back to factory settings as it does not have the keypad to enable this functionality.
2.
Most of the time when the error pops up it is due to problems with either the printer reading the cartridge is in from the contacts or the cartridge contacts are damaged.
I should also point out that refilled and remanufactured cartridges are the number one reason for the error but assuming that you are using hp cartridges fresh out of the pack take a look at this link and follow the steps. I would type them out but it even has pictures for easy reference!!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042818&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
If you are not using hp cartridges then replace with genuine cartridges and it will most likely resolve the issue - the printer is able to tell the difference between a new and refilled/remanufactured and often times will reject the cartridge because of this.
Jul 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP C5180 scanner won't scan an image
I'm running Windows Vista 64bit Ultimate Edition. Have the C5180, all-in-one. HP Solution Center continually closed, saying No HP Devices Found. I completely uninstalled the printer software, using the install utility. Then, using Add/Remove Programs, removed all of the other HP software on my PC. Then deleted the HP directory (in program files x86), and removed the HP registry key under software in both HKEY_LOCAL_MACHINE & HKEY_CURRENT_USER. Then rebooted. Once that was done and back up, I reran the install utility, but this time I followed the steps below (from here - http://hpanswers.blogspot.com/2007/12/no-hp-devices-detected-hp-solution.html):
Click on next until you get the below three options
(i) Recommended
(ii)Custom-------------->Select This
( iii)uninstall
Choose the custom install and click on next, ****
At begining of the installation, It gives you to 2 options
I) Yes, Check for updates..........
II) No, I prefer to do it Myself--Select this option and click on next
Immediatley in the next window ,you will have long list of softwares with the empty check boxes beside them.DO NOT select(check) Hp update, check rest of them and click on next to continue the installation.
You will able to open the HP solution centre with No errors.
Additionally, I did the following 2 steps, that I mostly found here (http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00897551&lc=en&dlc=en&cc=us&softwareitem=oj-54112-1&os=2093&product=1153481&rule=9653&lang=en)
Add the following files to the Trusted programs list:
hpqkygrp.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqscnvw.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqste08.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqtra08.exe , located in the C:\program files\HP\digital imaging\bin directory.
hpqthb08.exe , located in the C:\program files\HP\digital imaging\bin directory.
Open the following ports on the firewall utility by following the instructions provided by the manufacturer:
UDP ports: 161, 427 and 137
TCP ports: 9220, 9500 and 9290
Jun 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
May 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
Scanner won't work but the printer does
Ok here is the answer you have all been waiting for - look on the CD that came with any HP printer for the mac and you will see that it is for 10.3.9 and 10.4. I bet you dollars to donuts you have the new 10.5 leopard software and you got the new printer for free from the apple store.
All is not lost - go to the hp website at www.hp.com and on the left side you will see a grey menu that says software and driver downloads click on it and type your product. The version right now is 9.7.1 once you get all the way through. DO NOT INSTALL THE HP INSTALLER FILE - it is the same as the CD.
Well on the off chance your using windows the same applies - delete the old software on your computer and follow the steps above. The version number you will need depends on what OS but just make sure it is the most recent and you should be fine.
Jan 22, 2008 | HP PhotoSmart C4280 Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
98 people viewed this question
Ben Johnson
