I have a Toshiba Satellite A200 and have so for just over a year. the other day i was out and about using my laptop (plugged in) and everything was normal. After returning home a mere 25mins after i had had my laptop plugged in and working, i find that it did nto charge :|. i moved the cable so that different angles and tensions may allow me to charge which in certain places it did, then all of a sudden it did not matter what angle i had it at the thing wouldn't charge! I'm in desperate need of tha laptop and would appreciate any help. p.s. the charging sign does not come up when plugged in p.p.s. i have also tried to charge with an identical output charger, but still nothing! HELP cal
    Brigadier General:
  • 6,966 Answers
Based on your post/description, it would appear that powerjack has lost its solder connection to the motherboard or even justcold solder. This is a relatively easy repair. It would involvere-soldering at least two pins/points. What is more challenging is thedisassembly and gaining access to the bottom of the board to performthe soldering. Perhaps these pages maybe of illustrative help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
Hello, What cable or adaptor do I need to transfer all data from the hard disk of my Toshiba Satellite Pro A200 to my new laptop via USB port? Thanks.
You won't be able to transfer hard drive data by plugging one computer into another via USB. In order to transfer data, you will need to remove the hard drive from the Toshiba Satellite Pro, use an external hard drive enclosure, and attach that to your new computer with any USB cable.
The hard drive can be taken out by removing screws on the bottom of your laptop. The drive can be found in the bottom left of this picture: http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Here is an example of the exclosure you would need: http://www.newegg.com/Product/Product.aspx?Item=N82E16817816013
Mar 14, 2011 | Computers & Internet
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or...
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Jan 08, 2010 | Toshiba Satellite Pro A200-EZ2204X...
The headphones on my Tosiba Satellite Pro A200 dont work
it might be hardware technical problem.. i think headphone censor in the port is not working get it repaired from local service centre
Oct 01, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba drivers
hi..hello...try this web site to get the vista drivers>>(http://drivers-download-driver.com/tag/satellite-a200-24a)>>good luck and have a nice day
Jun 17, 2009 | Computers & Internet
How to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
May 27, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
