Question about Kenmore Elite 45986 Front Load Washer
Washer Impelling into Hot Water Line
When my washer (a Kenmore H3 elite front loader) spins, it pushes water into the hot water line with sufficient force to burst the connection hose to the hot water heater on the far side of the house (about 40 actual feet away) In short, it acts as though the impeller is connected to the hot water line, not the drain. This came on all of a sudden, and is very duplicatable.
We have temporarily prevented further damage to the far side of the house by shutting of the hot water to the washer, but the wife wants to use hot water in the washer.
Any ideas
    Sergeant:
    Champion:
  • 324 Answers
This sounds impossible,hold old is the washer? how long are the hoses to the washer?is it the temp pressure valve on the heater that bursts? can you hear the water draining out the drain pipe, this machine don't go into spin till the water has been drained.
Posted on Nov 03, 2008
How much water pressure do you need to operate a front loader kenmore elite. We have 28 psi from water well.
Check the following items:
1. The inlet screen at the hose water inlets to be sure they aren't clogged. With well water, debris can sometimes be an issue.
2. The water valve(s) are open
3. The water line(s) are not kinked
4. The water line(s) are not frozen
5. To be sure there is an available water supply, disconnect the water lines (hot and cold) and try running them into a drain while they are not connected to the washer.
Feb 08, 2015 | Kenmore Elite 45986 Front Load Washer
Water leaks out of the soap dispenser of my kenmore elite front loader and all the soap or bleach us not out
The 1st thing to try is to take out the dispenser ,there is a little piece that you will push down and then pull the entire assembly out, rinse it out with hot water ,most likely there is a build up in the dispenser,there after use only powder detergent, and no more then 1 tbs ,and any other stuff IE bleach ,fabric softener,use 1/2 the amount and dilute it with water.
Jul 20, 2014 | Kenmore Elite 45986 Front Load Washer
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front loader has hot and cold water reversed
I assume you verified the hoses are not crossed at the back of the machine??
:D
A better troubleshooting method is to call for a cycle of hot water and check that the proper solenoid on the water valve is being sent the signal. If it is, the water valve should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore h3 Elite Hot/Cold Water problems
I wouldn't imagine it being a computer problem, computers don't make mistakes like that. I would start with the inlet valve http://www.partselect.com/xq/aspx/Inventory.391478/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 and maybe the inlet valve wiring harness http://www.partselect.com/xq/aspx/Inventory.391563/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 for good measure. Both parts together will run you less than $100 and shouldn't be that difficult to replace. I'm am no Washing Machine expert, I just go by my common sense and Google. The computer http://www.partselect.com/xq/aspx/Inventory.971890/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 is $250+ and like I said I don't think the computer would cause the valve to open slowly and stay open, sounds like the vavle is sticking. Good Luck!
Apr 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Dshwasher has water on the bottom after cycle
your drain line is clogged or your pump is bad check both. the drain push a coat hanger down it and see if you can pull anything out.
Dec 08, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
61 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
