Question about EliteGroup K7SEM Motherboard
USB 2 & 3 Jumper settings Pictures and diagrams
I'm having trouble with the front 2 usb connectors, I can't get the jumpers wires set correctly, wire colors are white, black green, and red X 2
  • kennyskates Apr 20, 2009
    I'm having a similar problem but all my USB ports are not working when I go into device manager it tells me that they are functioning properly.
SOURCE: k7ama2 USB cable wire unplugged
the comon colors for usb are [red +5v] [white data -] [green data +] [black ground] and you need pinouts on your mother board also you may have 2 jacks so there is a 9 pin connector on board for external usb jacks, just get the manuel for it on internet but I need the motherboard number and make
Posted on Dec 12, 2007
JSPCEXPRESS
  • 178 Answers
SOURCE: motherboard diagram or jumper setting diagram
on the motherboard there should be something on it labeled usb1 or usb 2. Connect the wire to one of those.
Posted on Feb 13, 2008
  • 320 Answers
SOURCE: jumper settings for EPoX EP-8RDA3IPro Motherboard
For any motherboard the power and the jumper settings are common. Please clock on the below link or copy and paste it in your browser. The entire pc assemble is given.
PC ASSEMBLE----
"http://images.google.co.in/imgres?imgurl=http://www.ezbuildyourowncomputer.com/BareBones1%2520010%2520FrontPanelConnectors.jpg&imgrefurl=http://www.ezbuildyourowncomputer.com/RemoveCover.htm&h=270&w=360&sz=14&hl=en&start=4&um=1&usg=__upxkxY8-vUBhZ6uEFumejvwWcxE=&tbnid=qlpCOg4zFD3zbM:&tbnh=91&tbnw=121&prev=/images%3Fq%3DMotherboard%2Bmanuals%2Bfor%2Bpower%2Bconnections%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26sa%3DG"
CMOS SHORT------
"http://images.google.co.in/imgres?imgurl=http://www.pcbuyerbeware.co.uk/ClearCMOS.gif&imgrefurl=http://www.pcbuyerbeware.co.uk/ClearBIOS.htm&h=728&w=546&sz=18&hl=en&start=3&um=1&usg=__LxchryVCJTZvmufhnbWSIKWT2Ls=&tbnid=_x_3clEXoNn4oM:&tbnh=141&tbnw=106&prev=/images%3Fq%3DMotherboard%2Bmanuals%2Bfor%2Bjumper%2Bsettings%26um%3D1%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26sa%3DG"
Thank you....
Posted on Sep 11, 2008
SOURCE: connecting USB harness to mother board
Look on page 23 of the motherboard manual. Download it from here:
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=413&areaid=2&LanID=0
Posted on Jan 26, 2009
leecom72
  • 4806 Answers
SOURCE: The USB 2 & 3 have 10 posts each and my USB plugs have 4 openings
The USB pinout is as follows >>>>>>
Good luck.
Posted on Jul 01, 2009
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
How do I set the fusing unit correctly?
How to fix the Error: "Set the Fusing Unit correctly"
Ricoh Aficio SP C411DN & C410DN Color Laser Printers
Instructions:
1. There is a short Wire Jumper (color: black or white) on the inside of the main electrical connector of the Fuser Unit.
Note: These procedures can be done without removing the outer plastic housing of the Fuser Unit.
2. Press the side clip (or tab) and first pull the tab end of the large connector plug from the main housing of the Fuser Unit.
Warning: The connector plug wires are very short -- it extends a maximum of about 1 inch (or 2 cm) from the main housing of the Fuser Unit.
3. Use a small screwdriver and gently remove the small white connector that the Wire Jumper is plugged into.
Warning: Try to remember the correct orientation that this small connector is plug-in.
4. Use a small screwdriver (or a small flat blade) and gently raise the small tabs on the front of the small connector, while pulling gently on each end of the Wire Jumper.
Warning: Do not remove Wire Jumper forcefully by pulling.
5. Make sure that this Wire Jumper is plugged into the same pins as the one on the old Fuser Unit that is being replaced. There are only three pins that the jumper can plug into.
6. Reassembly the Fuser Unit by plugging in the two connector that were removed.
7. Replace the Fuser Unit into the Ricoh printer and secure properly.
8. Power on the printer -- it should start-up and go to the ready state without any errors.
9. The END.
Apr 26, 2010 | Ricoh 4506 Copier
Need a diagram of jumper settings for HP1070i DVD
i think you have SATA connectors not IDE if you have board that supports SATA devices, just plug it in on the SATA found on your board, but if you don't have yu need to put your drive on a enclosure so that it will become external drive and you can plug it on your USB port
Aug 15, 2009 | Computers & Internet
Can not get motherboard to boot up
the things youre describing that are not controlled by the same power connectors. the 1st set that works are powered i think by the main large rectangular power connector. the stuff that's not working require more power connections. the cpu fan has a small wire that connects to a small connector on the motherboard right near the cpu. the optical drive connects to one of the the 4 pin power connectors coming from the power supply, same with the hard drive- same power connector. the front usb light is going to connect to a specific tiny 2 pin connector on the mobo, it will be labeled with tiny white letters-- try to find or download the manual. godo luck!
Jan 31, 2009 | Foxconn 848P7MB-S Motherboard
Jumper settings
Hi
If you look on the top of the hard drive you will see a diagram of the positions you need, master setting is nearest the IDE connector.
Jul 04, 2008 | Maxtor Hard Drive
Asus p5pe-vm
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
"GND" = GND
May 15, 2008 | ASUS P5PE-VM Motherboard
Maxtor 500 gig internal diamondmax 21
external USB hard drives do not need to be jumpered, if your computer does not recognize the ext. drive probably it is because the enclosure is defective, when you connect the USB cable you should get the "ding-dong" connection sound.
If you think that your computer recognizes the hard drive then jumper it as "secondary" or "cable select" and install it INTERNALLY, then transfer your data, that will prove that there's a problem with the ext. enclosure.
One more thing, maybe the USB port you use is malfunctioning, try one that you know that works (assuming that you have other USB devices that work).
May 04, 2008 | Maxtor Hard Drive
Motherboard diagram or jumper setting diagram
Feb 13, 2008 | Intel D865GBF Motherboard
Sata as boot and install eide drive as d:or e:
You can slave the EIDE hard drive off of the CD Drive, as long has it is also EIDE. There should be a flat grey ribbon cable plugged into the back of your CD Drive. That IDE ribbon cable should have 2 connectors on it, one of them should be plugged into the CD Drive.
If it does not have 2 connectors, then go buy a new IDE ribbon cable that has 2 connectors, they are cheap. Or ask a friend, he/she might have extra, I always do.
Make sure you have the jumper settings correct on both drives. One will be the master, the other should be the slave. Or set both to "select select" and let the computer decide. The jumper is a little black jumper that connects 2 pins together on back of the drive. This tells the drive if it is a master, slave or cable select.
There should be a sticker diagram on each drive denoting the correct pin-jumper setting.
One other thing, when you hook up 2 drives to 1 IDE cable, both drives share the bandwidth. If you are using one of the drives, don't try to use the other, major performance slow-down.
Also, you don't need to slave the drive. You can get a Hard drive enclosure and make the drive an external drive connected by USB. They are also cheap, but make sure the hard drive has a partition and is formatted before installing it in the enclosure.
http://www.geeks.com/details.asp?invtid=COSMOS-525U2-SIL&cat=HDD
Nov 13, 2007 | Computers & Internet
EliteGroup K7SEM Motherboard Logo
1,162 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
