Question about Refrigerators
Electrolux Dear FixYa, I am experiencing extreme difficulty in removing a plastic evaporation tray which is full of contaminated water, bacteria & other mould and needs emptying & thorough cleaning, as it is smelling and may represent a health risk ! No obvious means of fastening which can be easily undone/dismantled is apparent, only a notice in 3 languages stating that 'The tray should not be taken away'.....this may suggest that it can be removed ? Please advise ! Chris ****. Bexley Kent. 31st October 2008. 10:25 AM. E-mail : ....chrisdyke2000@yahoo.com
  • 120 Answers
Criss nedd more ininfo but yes the pan ca nbe remove for cleaning but not all the time the wtr that collects there will evaporate and is neeed too since the condensor fan uses it to cool the compressor but yes you can remove is a top frezeer try from back but if a side by side then you need to tilt it to one side to remove the screwa that hold it in place
Posted on Oct 31, 2008
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
Apr 28, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
My mazda 6 v6 2004 smell oil when starting ventilation
The smell is typical of older Mazda aircon.
Purchase an aircon cleaning spray which is discharged into the aircon system by selecting recirc , cloing the windows for 5 minutes . This cleanses the system which is probably contaminated with bacteria.
Recharging your air con will help as well. The smell is due to evaporate condensed water mixed with sludge and bacteria .
Sep 20, 2011 | 2004 Mazda 6
My evaporation tray is full and smells as milk has split into it and gone off -it is making the kitchen smell. Does the evaporation tray unattach from the back of the fridge?
if you can get to the tray pour in some clorine bleach,or pour some down the drain hole,this will kill any smells/bacteria.(works with all fridges).
Jan 11, 2011 | Zanussi Refrigerators
I have an LG GNR346FW fridge. Water has begun leaking from the back left hand side. It looks like it's coming from where the evaporator tray should be located. Is it possible to access the tray to see if...
Hi and welcome to FixYa, I am Kelly.
You will have to remove the rear fiber panel and check the opaque plastic tube END at the catch basin tray for obstructions. Additionally you will have to do a maunal defrost by using a fan directed at the freezer compartment for at least 2 hours. The compartment drain is most likely frozen and the only way to make sure it has defrosted is to use a fan making sure that the freezer reaches room temperature. The standing water in the freezer drain acts as an ice insulator so just be patient with the water mess and clean up while you manually defrost it. You must make sure that the drain reaches above freezing for the ice blockage to be cleared.
If you need to access the drain the ice maker and shelving has to come out and the temp control knob pulled off to remove the rear evaporator acess cover. Be careful if there is a compartment light as those wires are easily broken. The light cover can be removed by locating the locking tabs and unlocking them with your thumb by gently squeezing the cover. If there is debris in the evaporator drain clear it. Some drains have a plastic screen that needs to be lifted out before you can clear the drain funnel.
Thanks for choosing FixYa,
Kelly
Dec 10, 2010 | LG Refrigerators
I have a frigidaire frost free upright freezer that seems to have temperature control prblems. I noticed that the compressor has a plastic tray on top of it. The tray was full of water. What is the...
the tray is there to capture the condensation. it will have water in it but evaporates so it doesn't overflow. if you're having temp. problems' it may be low on freon.
Aug 11, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Evaporation tray at back of stand alone refridgerator is full of .....? and smells. How do I clean it as it is fixed to the back of the fridge?
syringe out drain hole/pipe with clorine bleach(clorine will gas off and leave no smell after an hour or so)clean out tray with bleach,as it will kill the bacteria that causes the smell,the higher the himidity the more often you will need to clean drain/tray.(any clean water in tray ,use to feed your house plants,
Aug 04, 2010 | Zanussi Refrigerators
Freezer icing up
Experienced this problem with Evaporator coil icing up (coil is located inside back wall of the freezer compartment; the ice/frost was visibly blocking the series of louvers or slots along the bottom of the freezer back wall. I think the power outage caused partial melting of an already somewhat iced coil, but when the power was restored the water on the coil just froze solid. When these slots become obstructed the Refrigerator will not cool to its proper 36-40 deg.F temperature and the compressor motor runs frequently and the noise level is louder than usual. SOLUTION: fastest and safest way to Defrost this iced up coil is: (1) turn off 120V power / unplug refrigerator from the outlet; (2) remove all food to another refrigerator / freezer and take out ice cube tray & flip icemaker bail wire to its up (off) position - but leave top freezer basket in-place; (3) remove Bottom freezer basket (which should lift up and out; (4) move refrigerator away from wall - and carefully unscrew and remove white-painted, rectangular metal panel at bottom in the back....... you will see a white plastic water tray below a small fan with black plastic blades...... have a 3x5 cellulose sponge and bucket handy...... (5) open freezer door all the way and set a 21-inch box fan on the floor in the opening or area where the Bottom freezer basket was removed... put a single towel on floor under the box fan if there is significant frost on the bottom of the freezer compartment (there should not normally be any); (5) turn the fan to "Medium" speed with air flow pointing toward the freezer... you will be amazed at how much faster this works than pans of hot water or hair dryers (the latter is potentially damaging and dangerous); (6) with a flashlight you should soon see the water drip-drip-dripping from a spot at the center and bottom of the Evaporator coil - where it goes down a white tube and into the white plastic pan beneath the small fan you saw in Step #4; after awhile (maybe 20 minutes) check the white plastic tray in the back - which will be full of water (sponge it out)... continue defrosting with the 21-inch box fan... check the plastic tray again - and sponge out the excess water. A completely iced-up coil will probably fill the plastic tray three times. Eventually the water will stop dripping - which means the Evaporator coil is completely defrosted. There may be some water that gets onto the floor under the left side of the refrigerator which you will have to wipe up. Reattach the metal panel and reinstall the Bottom freezer basket and ice tray. This process takes long enough that you can clean the inside of the refrigerator while you're at it.
Jul 09, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Washing machine smells like stagnant water...making clothes smell bad as well. No visible water laying anywhere
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 31, 2009 | Electrolux EIFLW55HIW Front Load Washer...
CLEANING WATER LINE?
replace the cartridge but when you do put a cap full of bleach in the filter housing .run the water for a while and this should clean any bacteria that you think might be in the line from the filter to the dispenser, be sure to run the water through the dispenser and dispell all the bleach
Oct 10, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
My fujitronic is leaking water. Any solution?
hi friend,
Instructions
  1. Step 1 Pull the air conditioner from the window on a mild, sunny spring day. The sun shine will help in rapidly drying out the air conditioner after you perform the next routine process.
  2. Step 2 Place the air unit on a firm surface. Preferably a concrete slab or a few old boards. Do not place the unit on grass or dirt.
  3. Step 3 Use the screwdriver and remove the outer metal housing of the air conditioner. There are generally 4 to 6 screws along the lower edge of the cover that holds it to the frame.
  4. Step 4 Observe the inside of the air unit. Note that there is a plastic drain tray on the bottom. This drain tray carries away the condensation water from the cooling coil and allows it to flow to the outdoors and drip to the ground. The drain tray is plugged from last seasons collection of dust and bacteria growth.
  5. Step 5 Use the cup measure and pour some house bleach into the plastic tray. Allow the bleach to "work" on the nasty solids that have collected there for about 5 to 10 minutes.
  6. Step 6 Connect the gardenmag-glass_10x10.gif hose to the outdoor spigot and attach the spray nozzle to the hose.
  7. Step 7 Spray in the interior of the air unit with the moderate pressure from the spray nozzle. Force the water into the plastic drain tray and remove all of the solid debris that is laying there. Spray the interior and exterior coils as well since you have the unit cover off. You will have to remove the interior filter as well. Clean the filter while it is exposed.
  8. Step 8 Place another cup of bleach into the plastic drain tray and allow the liquid cleaner to set for about 5 to 10 minutes than thoroughly rinse the unit with fresh water. The inside area should be thoroughly clean.
  9. Step 9 Allow the unit to completely dry in the sun. When dry, replace the exterior cover and place the unit back into the window. The unit will be cured of leaking for another cooling season.
Tips & Warnings
  • Weekly cleanings of the interior filter will help in alleviating bacteria build up in the drain tray. Living in an outdoor dusty environment may create the need to perform the bleach cleaning more than just once a year
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Fujitronic FA-1300 Air Conditioner
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
