Question about Olympus Camedia C-765 Digital Camera
Won't focus when zooming into the subject
This camera was purchased 2 years ago. When we are taking pictures that need to be zoomed in the picture comes out blurred. I have tried to take the same picture with a tripod with the same result. The camera works fine when not using the zoom feature. When I zoom just a little it works fine, full zoom does not work.
  • Anonymous Jan 30, 2009
    camera will not focus when zooming in on subject
  • 188 Answers
It seems that the lense element which mooves while zooming the camera is stucked. normally this happens when the camera suffers a heavy jery, may be by dropping the camera. Resulting into disalingment of the lense assambly. You will need the help of repair shop to solve the problem.
Posted on Sep 15, 2006
I need help taking pictures with my DX6490 kodak camera. It does take clear pictures in a gym or auditorium when I need to use the zoom.
What is most important is that unless there is a slave flash or a more flash the subject might look quite blurred in the distance . You might need a SLR with a wide angle to get such pictures perfectly. Try to light up the area when it is indoor and see the result.
Dec 30, 2011 | Kodak EasyShare M530 Digital Camera
What is the difference in the optical and digital zoom?
Find the difference below
Digital Zoom
1. Digital zoom is a part of digital cameras, and camcorders, which helps to crop the entire image, and then digitally enlarge the size of the viewfinder of the portion that is needed to zoom in on
2. Digital zoom crops the image down to a centred area with the same ratio as the original, and also interpolating the result back up to the pixel dimensions of the original. this method involves cropping, hence the resolution and quality is reduced
3. Digital zoom, crops a portion of the image and then enlarges it back to size. And due to this, image quality is reduced in comparison with the original one.
4. Using the digital zoom allows the user to get closer to the subject when the photographer wants to be discreet about taking pictures, like taking a picture of a person in a graduation ceremony.
Optical Zoom
1. While taking a picture using a Camera to want to get a close shot of the subject without moving physically closer, photographers use the optical zoom.
2. The optical zoom ratio of a digital camera measures how much the lens can actually zoom in to make subjects appear closer. Optical zoom, enlarges a picture while keeping the resolution and sharpness of the picture high.
3. There is no relation between optical zoom and the resolution of the photo, as optical zoom only enlarges the whole image or the subject to a certain range. So image quality only depends upon the mega pixel (MP) of the camera
4. Optical zoom is very useful, while taking a picture of a landscape, or to get a closer view of a subject, without reducing the quality of the entire image, like taking a picture of a Rainbow in the sky.
Regards,
Ron
// Rate the solution with 4 thumbs up if the answer is satisfactory
Jul 01, 2011 | Nikon Cameras
I have problems focusing my f8000sd fuji camera when zooming in on small things.IIf I try to zoom right in on a butterfly for example,it will not focus and I can't use macro and get closer in case it flies...
Use spot metering & focus when taking pictures of an object.
Set your camera to highest Megapixel setting, Only use max. optical zoom on the subject (do not use digital zoom) .U dont need to get close to object as you can edit/zoom/crop the picture using any photo software program afterwards .
Aug 09, 2009 | Fuji Finepix Z20fd Digital Camera
How do you go from zoom to macro?
From my experience, many zoom lenses that have a macro feature simply kicks into macro mode when the lens is in fully zoomed position. Remember, macro is used to take pictures of something (usually like a flower, insect, etc.) and to magnify it several or many times larger than it really it is. And as a result the subject is huge and sharply focused with a very blurry background. Another thing to keep in mind is that there is usually a focusing limit for the lens in terms of how close one can focus a subject in MACRO zoom mode. In other words, you (the lens) may have to be at least a foot or more away from the subject in order to automatically focus sharply. On this note, if you have manual focusing capability, you should be able to take pictures in macro zoom mode from even shorter distance from the subject, resulting in more larger than life pictures!
I Can Fix it
Sep 03, 2008 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Instruction manual
I have an FZ7K, here’s what I do:
#1. Set the mode dial on top of the camera to “A”.
#2. Set the aperture to the smallest f/number possible, f/2.8, f/3.2, f/3.3.
#3. Now take pictures standing as close to the subject as possible, (or zoom the lens).
For even better results, have the background farther away from your subject.
Aug 20, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
How to delete picture from canon powershot s5is
Press the set button located above the menu button to erase a single picture. The set button is like an enter button on a PC
Apr 25, 2008 | Canon PowerShot S5 IS Digital Camera
P72 face focus blurry background
Hl, I'm not sure what shooting options the P72 has. But, even in Auto you should be able to do this (Auto usually picks a wide aperture). The key is to fill the frame (at least 50%) with your subject. So zoom in and focus on the face and then while 1/2 pressing, zoom back out a little. Then fire away. You should get an in-focus subject and slight blurring of the BG. You have to experiment with this. If you fill the frame too much, you might get such a small depth of field that the subject's nose is in-focus but the eyes aren't.
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus Camedia C-765 Digital Camera Logo
106 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
