Question about Sony Ericsson K750i Cellular Phone
Lcd backlight not working
I recently gave my 750i a new lease of life by changing the outer case, since then the screen backlight has not worked? is this a fault anyone else has experienced or is it coincidence?
  • maddie08 Oct 31, 2008
    great, thanks
Sound is damage and software cuurput cant not creat a new folder in each folder
Posted on Oct 31, 2008
  • 89 Answers
I think the screws around the screen are loose
you should tighten them
be carefull not to tighten them too much.
I have a problem with a gift from my sister, she gave me a viewsonic n2750w that she gave up on once it started to turn on and shut off on its own, i took it to my place, turned it on, the screen turns on...
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will solved this problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.The board is a long in shape.
Mar 22, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
LE26R74BDX blank screen, unreactive TV
Tries change power board,most cases,but some case the main backlight video board it dead,or both power and main backlight video board .My sugestions to u buy both power and main backlight video boards,tries the brand new power board first,if don't work,try it with the backlight video board with the old power board, same prob. tries both new boards.Trouble shoot this way u have base cover have boards in hand,must lose some money for return merchandise,for restocking fee.
Oct 31, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
When turning on my compaq presario F500 today the screen would not light up. With difficulty, I could vaguely see the IE window boxes & screensaver but cannot get the plasma light to work. Any ideas ? Its'...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 22, 2009 | Compaq Armada M700 Notebook
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Dell Precision M60 Notebook
Backlight on the screen not working
there is dim light on the screne
Nov 12, 2008 | Nokia N95 Cellular Phone
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
Nokia 6133 LCD Replacement Trouble
my guess is that you messed with something while you were prying it open.
I have the nokia 6126 (very similar) with a broken screen but i get it open, could you help me with that
Feb 14, 2008 | Nokia 6133 Cellular Phone
GBA SP Backlight Problem
try putting a soldering iron on the joints of the backlight connection and melt the solder in place and do it for both contacts. Try this and it might just be a loose connection. Dry solder joints hapen all the time in most new electronics
Dec 28, 2007 | Nintendo Game Boy Advance SP Console
Se w880i - phone starts then wont show anything on screen
Ok, so whoever said you need the flash, shold flash their brains! Your backlights are burnt on the LCD - to change it costs about $80 because you need a new LCD screen at the same time.
Dec 11, 2007 | Sony Ericsson Walkman® W880i Cellular...
SE 750i
yes try to reheat the display connetor on board
if you have a hot air. or use soldering iron use smallest tip so that you cannot touch the other parts.
here' the image
peace!
Dec 01, 2007 | Sony Ericsson K750i Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
74 people viewed this question
Top Sony Ericsson Cell Phones Experts
Sandeep Shenoy
Prashant  Sharma
Prashant Sharma
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
