Question about HP LaserJet 2420 Printer
Hp 2420 not starting up
When the printer is put on the screen that shows ready does not come on and the ready and data button also does not com on
  • Anonymous Dec 04, 2007
    Printer is not printing, but when I restart the printer, it gives the printing.
    Printer is a network printing. What is the problem.
    vind
  • Anonymous Dec 05, 2007
    My duplex mode printing prints wrong side on paper
  • 417 Answers
Hi there you both may have the power board blown the only way to check is plug in a new power cord if this doesn't work then will have to find a repair station.
Hope the cable works though
Please rate me
Cheers J
Posted on Dec 31, 2007
SOURCE:
My 5550laserjet hp printer showing 59.90 error
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Check this page out as well (parts) Error Codes and Support
Dec 21, 2017 | HP Office Equipment & Supplies
Lines on paper produced by lines on drums new
The link below will provide you with all the necessary information to fix issues related to the HP Laserjet 2420 Printer
HP Laserjet Troubleshooting
Also, try the steps below.
1. Turn the printer off, and turn it on again.
2. Force a calibration by selecting CALIBRATE NOW from the Print Quality Menu.
1. Press example (Select) to enter the MENUS.
2. Press example (Down Arrow) to highlight CONFIGURE DEVICE.
3. Press example (Select) to select CONFIGURE DEVICE.
4. Press example (Down Arrow) to highlight PRINT QUALITY.
5. Press example (Select) to select PRINT QUALITY.
6. Press example (Down Arrow) to highlight CALIBRATE NOW.
7. Press example (Select) to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
3. Perform a cold reset on the printer.
3. When the memory starts counting, press and hold the green example (Select) button.
4. Continue holding the green example (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
6. Press example (Down Arrow) button once. The control panel will display COLD RESET.
7. Press example (Select). The printer will perform a cold reset and then continue its power-on sequence.
If this issue persists, contact an HP-authorized service or support provider. ( 1-800-474-6836 )
If the Toner is newly purchased and it is because of faulty toner, HP will replace it for no charges.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | HP LaserJet 2420 Printer
Am not able to download drivers for hp laserjet 2420 printer
Hi, here's the link to your printer driver...
just click the link and press the "download" button.....save the file to start downloading...
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=416419&prodNameId=412123&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=lj-24947-4
Hope that fix your problem...
Much appreciated if you could rate this help.thanks.
May 24, 2010 | HP LaserJet 2420 Printer
My hp 2420 printer show me an error 49.2FD9
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
and look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
Jun 19, 2009 | HP LaserJet 2420 Printer
My hp leser jet 2420 printer shows me an error Error 49.2FD9 what is the solution
look here:
and this:
Error code
This is a ram dimm error try changing dimm(s) to other slots(s) please ask for more info if required
Oct 31, 2008 | HP LaserJet 2420 Printer
Hp 2420 displays 53.07
The 53.07 error relates to Memory. Turn the printer off. Remove the right side cover. Remove any and all DIMM (memory) cards and printer/network cables from the formater board. The memory DIMMS are located behind the metal cover. Remove any Jetdirect Cards installed into the EIO slot on the back of the formatter.
With all accessories removed power up the printer and see of it comes to ready. If not, you need a formatter board. If it does come to ready, power it off and plug one peice that you removed back in and try again. Keep adding one at a time and powering up again until the error returns. When you get the error, the last added back onto the machine is the problem.
Here's a copy of the service manual to help with disassembly, troubleshooting and part numbers for ordering.
http://www.feedroller.com/Store/Service%20Manual/LaserJet%202410%202420%20and%202430%20SM.pdf
Hope that helps you. If so, hit me with a fixya!
Aug 19, 2008 | HP LaserJet 2420 Printer
Long wait time
Hi there just check that within the properties of the print drive located in printers and faxes right hand click on the printer select the Advance tab at the top then make sure that the spool is either set to start printing after last or after first. Click on the print processor button at the bottom and change the graphic output to one of the other option then close and try the machine.. Once you have selected all of the options and you still have mo joy try a different data cable or connect via another port.
Hope this helps you
Thanks J
Jan 09, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
97 people viewed this question
Clive
Clive
Thomas F. Schneider
