Question about Maxtor Hard Drive
Quick question or 2
OKay, i got this computer from my aunt it will power up and nothing more. I removed the hard drive in hopes to insert into mine and not to sure how to go about it. i would simply install and turn my pc back on and its good to go or would i have to format it in some way? just want it to store music files etc. any help or links on installation and set up would be great. Thanks
    President:
  • 1,901 Answers
If this is an IDE drive, you will have to make sure the jumper on the end of the "new" drive is on "Slave".
IDE drives have a cable about 2 inches wide. This is probably what you have. The above link is for IDE drives.
Here is a link to help out: http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
(SATA drives have cables about 1/2 inch wide. You shouldn't have to worry about jumpers with them.)
Here is a youtube video that may help also: http://www.youtube.com/watch?v=vnEga6ga5hM
Once the computer recognizes the drive, you can format it by double-clicking "My Computer" on your desktop. Right click on the icon for the new drive and select "Format..."
Posted on Oct 31, 2008
It claims to be full. How do I empty it and start over?
It depends on your operating system but is similar for most windows versions.
For windows 7/vista
Click Start Click computer right click the flash drive and click format check quick format and then click start
Note: this will erase everything on the drive.
Mar 05, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
I built a computer for my aunt using an Intel motherboard, Intel processor, 2 x 500MByte DDR3 RAM in a Blue Ninja case purchased from Tiger Direct. The computer worked well for more than two years then...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 16, 2011 | RaidMax Ninja Case (RDMXNJACAS)
The hard drive does not "power up". The green
I'm assuming this is a USB external drive. It's likely that the drive is failing, but to find that out for sure you'll need to remove the actual hard drive from the housing, insert it in a computer as a slave drive, and run a diskchk on it to see if it's responding correctly. If that test is successful (ie., it tests OK and you can access the drive as a slave in another computer) then it's just the USB interface on the housing that's bad. You can always just get another housing (they're inexpensive and lots of them).
Hope that's helpful.
Jan 12, 2011 | LaCie (300703EK) 250 GB Hard Drive
The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
That's why the error message.
Just insert disk 1 again.
Shut down the computer (press & hold the power button for a minute).
Restart.
Follow the instructions that come up.
If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
Hope it helps.
Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
My computer went bad and I cannot get the data off of the storage drive. How do I proceed?
Hello Sir, hi, to access the hard drive data, you need to get the Hard drive out of your computer and place it on another computer.
to remove the drive. 1. power off the pc. 2. open the side panels to access the inside. 3. locate the Hard drive. the rectangular metal unit in front. not the CD drive okay. 4. remove the 2 cables connected to the drive. power and sata/ribbon cable. 5. loosen the screws. 6. Gently pull out the drive.
Ask a friend with a computer to help you out to get the data. or visit a computer shop to have your data back up tp a CD bring you drive along.
May 22, 2010 | Maxtor Shared Storage II (S01R320) Hard...
I inherited an inspiron mini but my aunt left her password in. I don't know the password. What can I do?
if you are willing to lose the data you can reformat the computer with these steps:
1) insert the windows installation disc
2) boot from cd
3) when you get to the hard drive manager part delete all of the hard drive partitions (it should make one partion)
5) format the one partition
6) install windows to that partition
Jan 08, 2010 | Dell Inspiron Mini 9 Notebook
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
Start up with hp6325us
i think its the pentium processor had one a while ago with same problem , dont take my word for it though, just a thought
Mar 07, 2009 | HP Pavilion dv6325us Notebook
Maxtor Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
