Question about Cameras
Sony DCR-PC5E showing low battery constantly, but battery appears to be OK.
    Brigadier General:
  • 6,966 Answers
Initially, I would suggest replacing/charging the batteries. This is to eliminate the possibility that is a battery/charging issue. Additionally, pls try to verify that the battery contacts both on the Sony and the batteries themselves are clean. You may need to scrape them off to assure positive contact. Further on the camera's battery terminals, you may need to slightly bend them (or stretch if spring type) to provide more pressure in the contacts (this is of course if the design will allow you to).
Should the above be not corrective, then in most likelihood, it is an internal electronic error.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
Download sony digital video camera dcr pc5e driver
Search box. Type in details. Loads of info.
May 02, 2013 | Computers & Internet
I need to down load drivers of mini DV sony DCR-PC5E
  1. look at manufactuers website
  2. look on google (not recommended
Aug 10, 2010 | Sony Handycam DCR-PC5 Mini DV Digital...
Error C:04:00
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Shamelessly copy pasted from another forum.
Jul 29, 2010 | Sony Handycam DCR-SR40 Camcorder
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Foggy display on screen
open it up then clean the lens
ben and peter jeffrey
Dec 26, 2008 | Sony Handycam DCR-DVD101 DVD Camcorder
Sony DCR-TRV320
Try this (seems to be a standard thing from Sony):
  5. If an error message appears, service may be required. If the error ,message starts with an "E" it needs to be sent in.
Go to any large photo shop and get an estimate.
Aug 23, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony handycam DCR-PC330E Mini, purchased in Tokyo, April 2004 - Was working as normal, then suddenly went 'dead' - no light showing when on charger (which had been working fine up to date), tried another...
This is not a monster you wanna open and play with as I've seen this puppy and its loaded with flex cables connecting all the differant pcb's together. You wanna take this or send out to a camcorder specialist please. You also need a special set of these cables to work on this unit as well as a few special service jigs. Good Luck
Apr 11, 2006 | Sony Handycam DCR-PC330E Mini DV Digital...
Sony DCR-HC40 Battery Charging Problem Hi Mates - I did purchase a Sony DCR-HC40 camcorder around an year back and it was working superb till few days back. As of date, i am facing a problem where...
Had the same thing happen to me. Went out and bought a new battery and it, too, does not charge. Apparently something messed up with the in-camera charging system. It will charge for several minutes (charge light illuminated) and then the charge light goes dark. Battery gage shows that there is virtually no time left on either battery (old or new). Anyone have any ideas other than a trip back to Sony?
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Data code problem pleeeeeeese heeeelp......
Here are some programs that might help you with your problem : DV Sub Maker (Freeware) from Mike Laba aka Krong makes DVD subtitles from DATECODE in SUB or SST format which can be used in Scenarist and ReelDVD. DV Date Time Changer can change the DATECODE. And the test version of Play DV shows the DATECODE when playing DV AVI files. See http://video2dv.com/ DV Date, (old name DVRecDate) a shareware Adobe Premiere plugin from Ilia Topolnitski stamps DATECODE in videos. A DVD Subtitler (also shareware) exists too! See http://dve.teletex.ru/
Sep 14, 2005 | Sony Handycam DCR-PC5 Mini DV Digital...
Cameras Logo
104 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
