Question about Cyberhome CH-DVD 300 DVD Player
SPHE 8202 S [Code : 9735 cannot change the REGION]
I have a OEM DVD Player, having SUNPLUS [SPHE 8202 S] Chipset.
REGION Changing Code : 9735.
After getting the Service Menu, the Cursor cannot be moved to "REGION" menu. So, we are not able to change the REGION.
I am literally striving behing this since last 1 year.
Please give any Solid Solution for this problem.
Thankful to you All...
sanju_raghu_4_u@hotmail.com
  • SANJAYMASTER Nov 04, 2008
    Dear Ps3-Rulez, there is no Battery on the Board of SUNPLUS. So, there is no question to remove and plug it again. So, the suggestion is useless.
  • 3 Answers
Ok im not for sure about this. if you have changed it before a couple of times you cant do it again. they only give it a limit. of not then you just cant take your other dvds and play it sorry i wish i could tell you how to fix it but you cant. maybe if there is a battery that saves your info i guess you could take it out and then put it back in. idk. hope this helps!
Posted on Nov 01, 2008
Technika LCD15.4DVDID-108 DVD Region Code?
The region code is within the DVDs firmware and in this sort of model is not changeable. Why not re-record the DVD with your computer and finalize it as the code you want.
May 28, 2017 | Televison & Video
Change Thomson DV3631 dvd player to multi region
There are 3 steps to do this
1. Turn on the unit
2. Open the DVD tray and press 9735.
3. Press 0-6 for the region.
Mar 29, 2012 | Televison & Video
Onyx sw2300xs free region 0 unlock code
Power on the DVD player.
Open the tray.
Key in 9735 on the remote.
Change region to 0
Close the tray to exit the menu.
Oct 10, 2010 | Televison & Video
My jwin model jd-vd509 does not play all regions,how can i change that? iwas given player in macau in macau as a gift,but find that the origanal dvd`s i bought in the uk and australia wont play,it comesn...
Don't know if it will work on your. I have a jWin JD-VD141 and the code works. Have the DVD tray open (means ejected) then press 9735. A menu will pop up and choose Regions 0 then exit. You DVD player should play DVD from all regions.
Dec 08, 2009 | Jwin JD-VD509
How do I unlock the region code on my Coby DVD298 Player?
found this surfing this website: http://forum.ecoustics.com/bbs/messages/2/581769.html
Unlock Coby DVD-298
Open DVD tray
Press 9735
This will bring up a menu to change the region code, after changing the code, go to exit menu.
Hope it helped.
Nov 18, 2009 | Coby Televison & Video
I have a AMW V99 DVD Player and do not how to use it. Need help. I do not have the manual or original remote.
AMW V99 DVD Video Player with Remote
Region code hack posted by TR, December 19 2003:
This seems to work for the AMW V99 ($19 in after Thanksgiving sale at Best Buy)
1) turn on the dvd
2) open the tray
3) enter 9735
4) change the region code to 0
5) exit to main menu
6) password 8888
Best $19 I ever spent! (Bestbuy)
Futher confirmation the 9735 hack DOES work. Also gives options to adjust rating (I assume to control the maximum rating of DVDs allowed) and a PASSWORD option, I'm not sure what this is for. I performed the hack with the tray both OPEN and CLOSED.
Other hack posted by trickypuss, January 14 2004:
Dunno if anyone else has tried this, but I put a backup dvd created with DVDXCopy into my V99 after using the region-free hack mentioned above. It asked me to input my password (default is 8888) and then the movie begins playing off the dvd-r. Password is input with the remote, and there's no confirmation. Just banged out 8888 and pressed play. Previously it would just sit there when I put in the disk without asking for password or anything. Neato. So this explains one use for the password function.
AMW S99 / V99
  1. Turn on the player (disc tray has to be empty)
  2. Open the disc tray
  3. Press 9, 7, 3, 5 (or 8, 5, 6, 1)
  4. Select region (0 = multi-region)
  5. Close the disc tray
Jul 01, 2009 | Televison & Video
Hi, i have a new MCD290 Philips DVD player but in that some dvd's are not running telling of wrong region, i came to know that i have to enter some region codes so that i can play all types of dvd's but...
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
Dec 08, 2008 | Philips Magnavox DVD/VCR Dual Player
Daytek portable DVD player
1- Push switch ON
2- Press setup on the remote
4- Using the remote enter 9735 and a number will appear on top right of screen
5- Using the Left/Right arrow change the region to 1,2,3,4,5,6,255 as you wish, 255 is region free.
6- Press setup again to save changes
7- Play your DVD
May 19, 2008 | Daewoo DVDS151 DVD Player
MULTI REGION
1. Switch on the DVD - without and DVD in it.
2. When "no disc" appears press the following sequence of numbers from the remote control: 9735
3. Choose the region (0 is universal)
Apr 11, 2008 | Yahoo YDP305 DVD Player
Portable Mustek DVD player indicates Wrong region
Thanks Guest Mar 07, 2008!
Solved my region problem with the code 9735.
Nov 30, 2007 | Car Audio & Video
Cyberhome CH-DVD 300 DVD Player Logo
426 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
