Question about Gigabyte GA-8LD533 Motherboard
Booting problem when I switch on the pc after reading memory it loads up to del command displayed then getting stack. I have clear the cmos but problem is still remain. can give me a solution for this. regds, nilan
  • kjnilan Oct 31, 2008
    motherboard gigabyte GA-8LD533
    regds,
    nilan
    Problem Solver:
  • 3 Answers
It can be your harddrive . Please try to change your hdd or format it with your windows cd using dvd writerdrive that is correct with no default on it. The is nothing wrong with your motherboard unless if your connections inside is incorrect for example your slave and master drives.
Posted on Sep 28, 2011
  • 4,234 Answers
It is possible that you have a bad memory stick. One trick that can sometimes verify this is to move the sticks around. If you have 2 or more sticks of memory, change their position. Since the matching of virtual to physical memory happens during the boot process, moving the sticks around will alter that connection. "User" memory is a little more tolerant of memory errors. Moving the sticks could move the "bad" spot to a less sensitive area and may allow the system to boot up. If that works, then you should attempt to test memory a little more intensively to determine the "bad" stick and get it replaced.
Dan
Posted on Oct 31, 2008
    Genius:
  • Gigabyte Master
  • 1,250 Answers
Change RAM then check
My hp 2000 laptop reads enter administrator password or power on password with a system disabled code 86632955
Try this Hope it works.5 to 8 character code on System Disabled screen
Laptop password system disabled codeAs the computer is booting, press F1, F2, or Del to enter CMOS setup.
In the CMOS setup, when prompted for a password, guess three times until you're giving the code. If, after entering the wrong password three times, the computer is displaying a 5 to 8 code, as shown in the picture, continue to the next step.
Write down the code and visit Dogbert's BIOS Password Backdoors scripts page to download Python and the free Python scripts to clear many of these types of passwords.
Dec 13, 2016 | HP Computers & Internet
Gateway memory
HOLD del key even before you start your computer, then you start your computer.
If that doesn't help, open your computer and clear CMOS on motherboard, find jumper called clear cmos, but first un-plug Power or turn it off (put switch to 0), then put jumper in clear CMOS for couple of seconds, then try turning it on, ..
If one slot doesn't work, I suggest you try free program: memtest86 ! IT will show you if you have slot or memory problem.
If none from above helps, put one memory out, then try, then put another in, and other out and try.
Hope it helps.
Oct 12, 2013 | Gigabyte Computers & Internet
I have a Toshiba A75-S2112 laptop. I hit the debug button when it was booting up and now it will not boot-up to anything. It just sits there with a black screen and the fan turned off. I am trying to...
The computer starts but, when you press a key, nothing happens.
You are probably in Standby mode and have a software or
resource conflict. When this happens, turning the power on
returns you to the problem instead of restarting the system.
To clear the condition, press Ctrl, Alt, and Del simultaneously
then select Shutdown, then Restart to restart the computer.
Mar 24, 2011 | Toshiba Satellite A75-S2112 Notebook
My pc won't boot and is not recognizing any commands such as del, f10 or f12, what can I do
seems like you might have to open her up and reset cmos. find your manual turn off power remove the 2 pin tab on cmos and place it 1 pin down or up depending on it position wait 10 sec then place back. power on and i hope this will do it
Feb 10, 2010 | Gateway GT5082 PC Desktop
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Compaq presario cq50 boot problem
try to update the bios
or maby you need will need to use ur xp disc and repair
Jan 27, 2009 | HP Compaq Presario CQ50-210US Notebook
Gigabyte ga-8ld533 mother board problem
i have a problem with my mother bord 8ld533.my head phone is not working properly also its working with a small sound,alredy a have installed my sound driver..can you help me please...
Oct 31, 2008 | Gigabyte GA-8LD533 Motherboard
Compaq presario 700 problem in booting
when starting press f1 or del it will enter into the bios there kept bios default settings and exit the bios and then see the system , till the same problem try to clear cmos
Mar 27, 2008 | Compaq Presario 700 470024-192 Notebook
MSI MS-7142 motherboard problem
try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
Jan 31, 2008 | MSI K8MM-V Motherboard
Computer booting problem
Hi, You backup Lithium battery may require replacement. The CMOS/BIOS not remembering you prescribed setting is an indication that though the settings were saved, they were not retained and therefore when booted would display the "F1" "Del" choices. Even if the new DVD writer is configured/attached as Primary Slave, as long as you set it to be the first bootable device, the computer would boot from the DVD first. Again, this is done in the CMOS/BIOS setup (as you have done). But the CMOS/BIOS must execute this if retained in its memory. In some rare instances, even with a new battery, this problem do occur. The issue is no longer the battery but discreet components along the memory B+ line such as a reverse protection diode, surface mounted jumper resistor. Hope this be of some help/idea. Post back how things turn up or should you need additional information. Good luck and kind regards.
Sep 29, 2007 | Dell OptiPlex 270 PC Desktop
Gigabyte GA-8LD533 Motherboard Logo
80 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
