Question about HP LaserJet 3055 All-In-One Printer
HP laserjet 3055 all in one Scan problem
All the drivers are installed correctly. even i can send prints on network, But still when i try to use the scanner, it says unable to locate the device??
It was working before.
    Sergeant:
    Champion:
  • 275 Answers
Which OS are u using ?
try uninstall and reinstall the driver from the cd itself
Posted on Oct 31, 2008
I have windows 7 and no longer have the installation CD for my hp laserjet 3055 what should i download and isntall in order to be able to scan and print
If Windows 7 can't detect your printer, you can try downloading the driver from HP's website :
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=4062
and choose the HP Universal Print Driver. I hope that will fix your problem. Thank you
Sep 16, 2011 | HP LaserJet 3055 All-In-One Printer
Can I do network scanning with hp laser jet 3055 printer
Yes you can print, fax & scan with HP Laser jet All-in-one through LAN port (wired or wireless). Un-install and re-Install driver and Check "Extended Capabilities" when prompted.
Feb 16, 2011 | HP LaserJet 3055 All-In-One Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Unable to scan on HP Laserjet 3055 on Windows XP
Sounds like a software issue - U might try contacting HP but do not hold your breath. If machine is out of warranty they want nothing to do with you and will refer you to some forum or whatever. Or they might tell you to get a new scanner compatible with a newer OS.
Jul 02, 2017 | HP LaserJet 3050 Printer
HP LaserJet 3055 scan over network. How does one set the Laserjet 3055 up to scan over the network? I'm running XP professional.I set the printer up through Control panel - printer and faxes - Add a...
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
Jun 29, 2009 | HP LaserJet 3055 All-In-One Printer
Scanning from the network
Dear Friend,
Install the printer driver on your computer and than download fix scan utility from Hp.com. After installing fix scan utility You will be able to scan.
You have to do the same on every computer from where you want to scan.
Regard
Under Trainee
Dec 17, 2008 | HP LaserJet 3055 All-In-One Printer
Sacnner is not installed
Did you install the network drivers on the network pc your trying to scan from?
Aug 12, 2008 | HP LaserJet 3055 All-In-One Printer
Wireless router
hmmm..that's a bit different print servers usually only handle the print driver..check with your router folks to see if that's not the case. HP only sends what is available. The router is in charge of what gets through.
Mar 10, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
238 people viewed this question
Ben Johnson
