Slaving my hard disk
Well i dont know how to slave my harddisk.can you give a brief explanation
  • 52 Answers
Hmm..
it's hard to put it on words, but ill try my best.
1st Inserting and removing the IDE cables and power cables :
- 1st of all you should know how to insert the IDE cables and power cables, but before you remove the cables and put it back again, try to observe the color of the cables, the Red color of power cable is parallel to the red color of IDE cable. so when you insert it again, you put it on the same way, the Red color of each cable must be parallel.
2nd putting the jumper:
- try to check the printings on you hard disk at the bottom, and see if there's any tutorials on how to put the jumper.
3rd access the BIOS:
- to access the BIOS, click Del. Hence, before you modify any settings there, MAKE SURE to remember those settings that you modify, so that when there's a trouble you can put it back to it's default setting. Ok let's continue, if your BIOS has an auto-detect it will directly detect the Hard Disk drive that's being installed, if not you will manually detect it on the different Hard Disk setting. After modifying save and exit setting and reboot your PC.
i hope this helps you.
Posted on Nov 01, 2008
I got a maxtor ide harddisk which was already partitioned, i tried to format one partition for installing windows, but seems thare were bad sectors i tried to format all but it was not possible. Now the...
When a hard disk has bad sectors, the magnetic layer is worn out and the number of bad sectors will increase. If you keep using this hard disk you risk losing your data. This hard drive cannot be repaired, throw it away and get a new one.
Jun 25, 2011 | Computers & Internet
Cannot be detected by the computer
Good day,
For now I myself cannot give you a proper answer, but i can give a couple of options and/or rather a couple of tips on how can you make your computer detect your harddrive.
First i'd like you to provide the following:
1. Your computer specs.
Let's proceed to the tips:
1. Make sure the pin allocation is correct. ( You will find a 8 pins at the edge of your harddisk) This pins must be bonded together correctly for your computer to tell whether your harddisk is the master or the slave.
2. Check the IDE or SATA cable and see to it that it is properly connected to your hard disk and to your motherboard port.
3. Check the BIOS and see if the harddisk is enabled or not. At the side of the hard disk's name in BIOS you will see (well most of BIOS has this thingy) an option, this option is the detect option, click it and see if it does detect your harddisk.
If the tips above didn't work kindly update this post and kindly provide what i asked you to then we will fix you problem in no time.
Thank you and have a great day.
Apr 13, 2010 | Maxtor (A01E250) 250 GB Hard Drive
I have install external harddisk in slave, that hard disk is sowing in disk managment but not working
HAS THE HARDDISK BEEN ASSIGNED A DRIVE LETTERIN DISK MANAGEMENT. IF NOT RIGHT CLICK THE DRIVE AND CLICK ON "CHANGE DRIVE LETTER". YOU MIGHT EVEN HAVE TO PARTITION AND FORMAT THE DRIVE TO GAIN ACCESS.
Apr 09, 2010 | Computers & Internet
New extra harddisk
u need to make the first hard disk as master and second one as slave..
reset he jumper as shown in the face of harddisk
connect it with the cables and power supply
manage bios
restart
Mar 10, 2010 | Computers & Internet
My boot screen shows secondary slave hard disk error press F1 to resume. if i press f1 it enters into bios setup and the i press esc discard changes logging into windows but secondary disk is not detected....
Check on harddrive you find jumper on it.
Then read on harddisk you can find there is specifiaction for master, slave and cable select jumper settings.
Put jumper as cable select then check.
Also reconnect sata or ide and power cable to harddisk.
Then check .
Let me know if you need more assistance.
Thanks.
Oct 02, 2009 | Computers & Internet
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
Primary Master/Slave Hard Disk Error
Honestly, this is the best software I've used for file recovery:
http://www.ontrackdatarecovery.com/file-recovery-software/
It's a bit pricey, but if your data is important, it's worth every penny.
Hope this helps!
Mar 28, 2009 | Audio Players & Recorders
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Can u help me?
to slave a hard disk, first you must set its jumper setting to slave because if you dont set it, your system will be on chaos because the system will be confuse who will be its master harddisk. so after setting it, power on and check at its BIOS if your new hard disk is registered to the system.
Mar 13, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
