The dvd player keeps turning itself off, it turns on for a couple of seconds self checks itself and then turns off, and starts turning on again. it won't stay on long enough for me to open or close the disk slot.
  • aroha4 Nov 25, 2008
    My Hard Drive DVD player will go for a little while then turns off
  • random345435 Mar 06, 2009
    Same here.
epik559
  • 44 Answers
SOURCE: magnavox mwr20v6 turns itself off
The dry board is dead. or "power board."
Posted on Nov 25, 2007
SOURCE: Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
SOURCE: lg dvd drawer opens by itself and wont stay closed
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
Posted on Jan 28, 2009
SOURCE: Disk tray wont stay closed.
I am having the same problem with panasonic Karaoke player, it wont play anything cause the drawer wont stay closed!!! HELP!!!
Posted on May 15, 2010
The link DOES solve the problem. Worked for me even with another LG model number not listed there. Thanks!!! :)
Posted on Jul 06, 2010
Pan. dmr-e85h turned itself on, self-check
Open case and look for failed capacitors, which are cylindrical and will have a bulging top and a yellow/gold substance leaking out. If this is the problem, search for previous solutions that mention "solder capacitor C1260" for the DMR-E85. I had a similar 'no power' problem with my DMR-E55 and my son and I were able to fix it Sunday. Not hard to do and mine is working again!
Aug 05, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Jan 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Self check
Please be a bit more specific if you can. In what way is it repeating itself? And once it comes on does it stay on? It could be a component faulty on the power supply side.
Sep 26, 2008 | Panasonic DMR-E55 DVD Recorder
I need the Remote Master 562 code for a Nikkai DVD. It's not mentioned in the instructions.
Turn on your dvd player, press the DVD mode button, hold down P+ and V- for a couple of seconds until the power button stays lit up...then enter 0005 on the keypad...then, once again, press DVD mode, hold P+ and V- until the power light comes on, and then just keep hitting the power button...
when your dvd player turns off, thats the right setting, immediatly press P+ and V- to store the code...
Aug 23, 2008 | Televison & Video
Panasonic DVD recorder
A self-check for these models can sometimes last for 3-7min's (sometimes longer) depending on how much recorded data is on your hard drive. Plus it checks all unrecorded space on your hard drive as well. Don't forget that it must check 200Gig. If it self checks for longer than 20-30mins turn off at the wall and let cool down. Try again in an hour or so and it should rectify itself. If it continues to self-check for longer than 20-30mins refer your machine to an authorized technition
Nov 28, 2007 | Panasonic DMR-E80H DVD Recorder
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
My dvd Player started turning itself on and off all by its self.
don't bother fixing it, bring it back to store. You'll void any guarantees by tampering with it. Most likely the power button is damaged in some way. These are not repairable.
Oct 10, 2007 | LG DN191H DVD Player
Televison & Video Logo
647 people viewed this question
Top Televison & Video Experts
Electro Med Services...
