Question about Zebra P330i Thermal Card Printer
MECHANICAL ERROR Hi,when you give the execute command from the pc,then this message appears. ie. MECHANICAL ERROR
  • 2 more comments
  • Anonymous Nov 11, 2008
    i bought new printer head for my zebra p430i printer when ever i execute it say mechanical error or out cards while is full of cards please can some help me as i have to print thousand of cards for my client and they waiting for me.
    this is my email edarboe@pristineconsulting.com
  • ahsanbutt Dec 23, 2008
    I have the same problem Mechnical error also i do the cleaning the printer with cleaning card but the problem still there. Kindly post the solution as soon as possible.
  • dguyette Jan 13, 2009
    I have the same problem. Even if I clean it it quickly reappears...Is there an adjustment some place...
  • Anonymous May 04, 2009
    I was do all the technical guide to solve the MECHANICAL ERROR problem, but it still error,
Did you check if any card is stuck inside. Run a cleaning card. For that you need to press the button for 3 secs and it will start the cleaning cycle. Feed the cleaning card in the feeder and later from output.
Posted on Dec 07, 2008
Error 5 access is de ied
This error code is usually a network error code that tells you that you are trying to execute a network command when you are not at the level of an network administrator. If you are administrator it may be that you are administrator of your local machine, but not the network. In some cases you can use the local administrator as the network administrator (they function the same) and in others not.
If you are certain you are an administrator...logged in as an administrator...you may need to run a command prompt (cmd) as an administrator. To do this navigate to the cmd (Dos prompt) icon in your Start, Programs, (Accessories?) folder, right mouse button click on it, select "run as administrator", say "okay" and then issue your network command from the prompt.
good luck
Jun 15, 2014 | Microsoft Windows 7 Ultimate for PC
Data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system settings.in upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services only.click on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
Oct 24, 2011 | HP Pavilion DV6000T 15.4­ NOTEBOOK LAPTOP...
DEP as IE shuts of
1. Start Control Panel System and Maintenance Performance Information and Tools Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.
Alternatively
A) In the command prompt, type bcdedit.exe /set {current} nx AlwaysOff and press Enter.
B) You should get a success message back
C) Close the command prompt.
D) Restart the computer to apply.
A) In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter.
Regards
Oct 24, 2011 | Microsoft Windows? Vista Home Premium...
Hi there, I am building a java application which will call to praat for some execution of sound. I managed to call and sendpraat to praat from java application by java runtime.exec() But the praat seem to...
I was able to solve this problem..........
My java code is following........
String[] sendpraatCom = new String[3];
sendpraatCom[0] = "./sendpraat";
sendpraatCom[1] = "praat";
sendpraatCom[2] = "execute " + "<filename.praat>";
Runtime run = Runtime.getRuntime();
run.exec(sendpraatCom);
Now it is working properly.......
Dileepa sisila chandrasekera.
Department of Computer Science and Engineering
University of Moratuwa
Sri Lanka......
Apr 02, 2011 | Praat
8007007 MSN ERROR
Reregister SSL security libraries. To do this, click "Start," click "Run," and type in each command below and hit ENTER.
Note: After each command is executed successfully, you will receive a "DllRegisterServer succeeded" message. Wait until you receive this message before you continue to the next command.
a. REGSVR32 softpub.dll
b. REGSVR32 wintrust.dll
c. REGSVR32 initpki.dll
run reginout cleaner to easily fix it
Nov 01, 2010 | Microsoft Windows Live Messanger
Messenger 2009 error 8007007e
a. REGSVR32 softpub.dll b. REGSVR32 wintrust.dll c. REGSVR32 initpki.dll also run reginout cleaner to fix it
Oct 17, 2010 | Microsoft Windows Live Messanger
WINDOWS LIVE MESSENGER AND SKYPE TROJAN PROBLEM.
do this
d. REGSVR32 Rsaenh.dll
e. REGSVR32 Mssip32.dll
f. REGSVR32 Cryptdlg.dll
g. REGSVR32 Dssenh.dll
h. REGSVR32 Gpkcsp.dll
i. REGSVR32 Slbcsp.dll
j. REGSVR32 Sccbase.dll
Download some antivirus, scan ur pc,
download reginout intel partner, to fix errors of registry
Jul 29, 2010 | HP OfficeJet 6210 All-In-One InkJet...
When i use photo share to add pics it dosent appear clearlly
Unfortunately you do not give the error message - This feature relies on Internet Explorer ( Even if you have another browser set as default) and IE Flashplayer to function
Update IE
Update IE Flashplayer
Use a software Updater to keep check on your updates
http://www.filehippo.com/updatechecker/
Jan 18, 2010 | Yahoo Messenger
Im getting error messages at the bottom of my page:saying page done but with errors using ie 7 vista system
You can try running the fix from the following website on the affected machine to reset the IE 7 to factory defaults.
http://support.microsoft.com/kb/923737
In case the above link doesnot work. Following is the manual method for reseting IE
To use the Reset Internet Explorer Settings feature from Control Panel, follow these steps:
  1. Exit all programs, including Internet Explorer (if it is running).
  2. If you use Windows XP, click Start, and then click Run. Type the following command in the Open box, and then press ENTER: inetcpl.cplIf you use Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg. Type the following command in the Start Search box, and then press ENTER: inetcpl.cplThe Internet Options dialog box appears.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer settings, click Reset. Then click Reset again.
  5. When Internet Explorer finishes resetting the settings, click Close in the Reset Internet Explorer Settings dialog box.
  6. Start Internet Explorer again.
Thanks for using fixya
Proton
Nov 24, 2009 | Dell Inspiron 530s Desktop Computer...
System error in printer hp deskjet 3320
Normal 0 In XP go to Control Panel
Open System
Click Settings under Performance
Click the Data Execution Prevention tab
Make sure Turn on DEP for all programs is NOT checked, check Turn on DEP for essential Windows programs.
Apr 04, 2008 | HP DeskJet 3320 InkJet Printer
Zebra P330i Thermal Card Printer Logo
1,476 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
