Question about Tascam Audio Players & Recorders
Hi, I have a Tascam 144 when i plug my guitar through an amp into it, it only seems to record on one channel IE it only comes out of one speaker, I can get round this by taking a lead out of the sub out and the line out of the amp and plugging into both inputs on the 144, but this is hard to balance and just doesn't seem right. how am i meant to connect the guitar? when i look at the booklet it shows the guitar going into only one input and it says that i should not use both. What am i doing wrong. Thanks
  • 2 more comments
  • timson Oct 31, 2008
    its Cubase LE it came with the 144
    THANKS: if i do that it says stereo mono mismatch with the other channels, any ideas
    Cubase LE
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi
    What software are you using to record with?
    regards
    robotek
  • 1,512 Answers
No worries, you need to set up the channel you are recording to as a mono channel. It is the two overlapping o symbols in the track setup. Hit that and you should be in business.
Posted on Oct 31, 2008
I have the us 122 mk2> so this is the issue, it seems simple to fix but when i plug in my guitar in the (guitar in jack) it records it beautifully but it is only coming out one speaker and i can see on...
HI,
If your recording show that it is only coming out of one speaker, there is a setting you need to check. When you record, check if the file is being saved in stereo. It might be set on Mono that is why your only hear on one speaker.
Cheers!!
Sep 02, 2010 | Tascam US-144 Sound Card
I get no response from my Tascam US-144 and windows 7.
Go to program,look for tascam folder and adjust channel 1&2 to analog.This should make your music program work fine.And then do research on both analog and digital recording.
-William Marcelin
Apr 09, 2010 | Tascam US-144 Sound Card
Tascam Us-144 Only plays back in left speaker
If you have a condenser mic you need an adapter that you plug both into the right and left...
Jan 18, 2009 | Tascam US-144 Sound Card
Can't get a signal with my Tascam US-144
Make sure the Tascam is has updated drivers. The latest driver is Version 1.12. Something that helped me as well was to re-route my sound card to the Tascam. Meaning to have Windows, use the Tascam as the sound card for the computer.
This is the advice I followed from a forum it helped me alot!
I eventually disabled all other sound cards on my PC. In my case it was simply the integrated soundcard on my motherboard. I did this in the bios setting. I also uninstalled the drivers for it, just in case. I was having problems hearing anything in Cubase before I did this.
I set the US-144 as my default sound device in Windows (Control Panel>Sounds and Audio Devices>Audio)
I'm not sure what you are trying to record so I will give you a guitar example.
Guitar plugged directly into LINE/GUITAR IN R using the 1/4" jack with the switch above it in the GUITAR position. You can use the INPUT R dial to adjust the input volume for this channel. The SIG/OL light should turn green when you strum the guitar.
The US-144 is plugged into a USB 2.0 port on the PC.
Speakers are plugged into the LINE OUT jacks on the back of the US-144. The MON MIX dial will adjust what goes out through these jacks. If you move the dial all the way to the left, you will hear the input from the guitar directly from the US-144. If you move the dial all the way to the right, the signal goes through the US-144, into the PC via the USB connection, then back to the US-144 through the USB cable, and then out through the line out jacks. You may not hear anything when it is all the way to the right until you have Cubase open and configured properly. IMPORTANT NOTE: If you have MON MIX dial turned all the way to INPUT, you will not hear anything being output from your computer.
The LINE OUT dial adjusts the volume through the LINE OUT jacks. Make sure this isn't turned all the way down.
At this point, you should be able to turn the MON MIX dial all the way to INPUT and hear your guitar. It will probably only be coming out of the Right speaker, which is what it should be doing. Now turn the MON MIX dial back to somewhere in the middle so you can hear both the input from the guitar and your PC.
I downloaded and installed any updates that were available for Cubase LE 4 (I think all I needed was the 4.1.3 hotfix).
In Cubase goto Devices>Device Setup>VST Audio System and choose the US-122L /US-144 ASIO driver from the pull down menu. I'm not sure how important the "Relase Driver when Application is in Background" checkbox is, but mine is unchecked. If you click on the US-122L / US-144 section, you will see a button for the Control Panel. It will tell you what your driver and firmware are and what USB mode you are operationg in, etc. I didn't mess with any of these settings, but it is good to know how to get there. You should also see all your in's and outs. I have 2 analog in's and out's and 2 digital in's and out's. I am only using the analog in's and out's. Hit OK to close out this menu.
Now goto Devices>VST Connections and you should get a new window. There is an "Inputs" tab and an "Outputs" tab. Under Outputs, you should have a Bus for Stereo Out using the US-144 as your Audio Device and the US-144 Analog outs for the device ports. Make sure the "CLICK" colum is checked if you want to hear your Cubase metronome through your speakers. If you don't have a bus, add one and set it up as I have described.
Now goto the Inputs tab and add a mono input using the US-144 analog in R as the Device Port.
Now start a new project and add an Audio track using the Mono in and stereo output. Use the Edit Channel Setting button if you have to change your input and output.
Now with the MON MIX dial all the way to the right and with the Monitor button enabled on your audio track, you should be able to hear your guitar through Cubase.
Now if you turn on the Record Enable Button on your track and then press the Transport Record button, you should be able to record your guitar. Hit stop and then go to the beginning of the track and hit play. You should be able to hear what you just recorded. Don't forget that if the MON MIX dial is all the way to the left, you won't hear anything from your computer.
Well that is my Cubase LE / Tascam US-144 Getting started guide written by a newbie for newbies. May my pain and suffering alleviate some of yours. Good luck.
Dec 26, 2008 | Tascam US-144 Sound Card
Tascam US-144
Can you tell me how you have the 144 connected to your speakers, and your computer? Besides that, one quick fix might be to turn the MON MIX in the upper left corner, all the way to the right.
If that doesn't help, please post your ins and outs.
Nov 12, 2008 | Tascam US-144 Sound Card
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
I've just got a tascam dp01cf recorder and i'm having trouble with it, its abit hard to understand what to plugs in were, i'm using a electric guitar,a yamaha magicstomp effect pedal and a amp. also i'm...
You have a couple of options with your guitar input. You can either plug your guitar directly into the right (Hi-Z) input and use the Tascam's onboard effects with it instead of your effect pedal.
You can put your pedal in the chain between your guitar and the (Hi-Z) input. So guitar into pedal is, pedal out into Tascam Hi-z in. (Still doesn't use the amp).
Or my preferred method for recording guitar would be to mic the amp. In that case you'd just input a microphone (placed about 8-12 inches from your amp) and record your guitar that way. The mic would be plugged into either one of the Tascams two mic inputs to record the amps speaker output while your guitar, pedal and amp would just be hooked up in the normal way.
Please note: Never plug the output from an amp into any of the Tascams inputs. Those inputs are line-level and the speaker output level which comes out of an amp out would damage your Tascam.
To get a backing song into a track in your Tascam, you'll have to first, using a PC, get the song into a 16 bit mono Wav file format. Then you'll have to use the USB import function to copy that wav file onto your Tascam onto the CF media cards fat partition. From the you'll be able to import it into the Tascam choosing which track it will import into.
Cheers,
BD
Apr 17, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
US-144 noise
Hi
Usually Noise comes from distortion such as Electricity (50-60Hz), Main reason audio input cables might have shielding problem. Make sure cable is connected well and shield is not destroyed. You can understand it when you unplug the input connection and use the Computer volume by playing a digital media. If distortion persists contact to TASCAM @+1-323-727-7617
Good Luck
Jan 11, 2008 | Tascam US-144 Sound Card
63 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
