I have an idisgo lite mp3 player (512mb) which is stuck on repeat and only plays one song, how do i turn this off?
Toturn it off just hold down the playbuton and the lite should go off
Posted on Nov 23, 2008
In settings u change the option of repeating in audio
Posted on Oct 31, 2008
Alba mp3 stuck on repeat
I'm having the same problem! I press forward and it keeps playing the same song all the time, the repeat is not on. The mp3 player worked fine for about 2 weeks and then suddenly this happened,,,
Does anyone know how to fix this?? I'd be grateful for any help.
Jan 26, 2013 | Audio Players & Recorders
The songs are stuck on repeat. wont change to the next song on its own, has to be done manually.
When song is playing tap center of display to bring up settings.On left side tap the two arrows following each other to turn off repeat function.If a two is showing this repeats current song only.No number repeats all songs when reaches end.
Nov 08, 2010 | Apple iPod touch
Using oakley thump pro 512mb, once reset glasses comes on but unable to use any of the controls to change song forward or backward or even to change volume. this is after fully charging them. what could...
I'm having the same problem....also if you try and forward to the next song...it will repeat that same song 3 times. Its almost like the volume butons are stuck or something...they dont seem to depress the same 9you dont feel a click or anything)... weird.
Aug 14, 2010 | Oakley Thump MP3 Player
Playing by album
To change the play mode on the GPX ML648B you need to play a song, hit the MODE button on the side of the player and select Play Mode.
The options are INTRO (this will play about 10 seconds of a song and then go on to play the next 10 seconds of every song.) NORMAL which will just continually play through everything on your device, Repeat One, which will repeat one song, FOLDER which I'm not sure of, FOLDER REPEAT which I assume repeates a folder, REPEAT ALL and RANDOM.
May 19, 2010 | GPX ML648B MP3 Player
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Nov 03, 2008 | Nextar MA933A MP3 Player
Stuck on one song
try fiddling with the repeat option. you might have changed it and it just didn't register.
Jun 03, 2008 | Samsung YP-U3 MP3 Player
Graig MP3 problem
will not connect to PC
Feb 08, 2008 | Audio Players & Recorders
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
My MP3 player only plays the first 10seconds of a song.
maybe it's on intro mode, where it only plays the first ten seconds. enter the menu when a song's playing and change it to normal mode
May 26, 2007 | Supersonic SC-301MP3 MP3 Player
Omni 512mb mp3 player
The file formatt needs converting to mp3 or WMA ive got the same kind of MP3 player and this happened to me it didnt go threw the converting stage it just downloaded straight onto the player.
Dec 19, 2006 | Omnifi DMS1 Home MP3 Player
217 people viewed this question
 Grubhead
Grubhead
