AOpen AX45-V  Motherboard
Problem for AOpen AX45-V (91.88I10.004) Motherboard
No Display on screen.
By DJB99 on Sep 15, 2006
Here is my problem, I have installed this AX45-V motherboard and there is no output from the video card. I think that I have everything set up properly, everything is running and all of the lights along with the fans are on. The processor is fine, the processor works on another pc. Even though you can not see the POST there seems to be no beeping. The hard drive is running the memory is installed properly, and so is the cpu. I can not see the bios, I know that the screen is good. The video card that I have is VGA, it is a S3Inc. SAVAGE 2000. As I mentioned before everything seems to be running when I turn the computer on, there just seems to be no video displaying that I may be able to set this pc up.
Same Problem
Apr 26, 2008
-   I Have An Msi RD480 Neo-2 Motherboard, When I Switch The Pc On I Get No Display! I've Tried New Graphics Cards Any Ideas How To Solve This?-   suzi4tom
Mar 21, 2008
-   i dont have image on screen
what is the solution for this problem and what cpu fits on this motherboard
-   charvel666
Mar 20, 2008
-   Power is on.No display on screen-   Guest
Mar 20, 2008
-   every-   Guest
Jan 19, 2008
-   I have the same problem and i have tried different graphic cards and also putting thermal compound on the processor and then reducing it a bit, still no display. Only thing more i can add is the d-bracket indicates that it stops on the memory test. I tried swapping the RAM and then even with no RAM, but still no luck!-   rockyz
Solution #1
posted on Sep 15, 2006
Somewhat Helpful)
habib_101
Rank: Wiz
Rating: 79%, 458 votes
If available, try using a different video card to see if it will POST. The only other thing I can think it might be is that the processor isn't seated correctly, or that it is seated correctly but you have too little, or too much thermal compound on the CPU.
Was this helpful?
Yes
No
Popular Solutions for AOpen AX45-V Motherboard
Questions and Unsolved Problems for AOpen AX45-V Motherboard
Do you recommend AOpen AX45-V (91.88I10.004) Motherboard?
Answer
Answer
the motherboard foxconn n15235 its compatible with processors intel core2 duo and intel core2 quad?
Answer
Hi, i have ecs motherboard A780GM-A Ultra (V1.0) and when i insert powercolor hd 4730 graphic, some... (More)
Answer
i've hooked everything up on this motherboard and i dont have any video
Answer
i have mother board aopen ax 45 i was rewindows my pc then i not abal to get sound on my pc because... (More)
Answer
dual core support ata133 support 240 pin 4gigs ram
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 14, 2008
same thing computer works fine other than no picture i know it does because sometimes i hear windows loading as well as i can still see shared folders on other computers on my network
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For AOpen AX45-V Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
