Question about Samsung SF-340 Plain Paper Inkjet Fax
SF-341P Hi Can you help I have a message on my fax showing remove paper jam and then press stop/clear there is no jam, i have turned machine off as I hardly receive faxes cannot understand why Can you help regards Mana
  • 25 Answers
Remove all papers from the machine, unplug it from the mains suply and try all over again,
If the problem persist most probably there is a broken or an unplug actuator sensor inside the machine or in the scaner area.
GOOD LUCK.
Posted on Nov 01, 2008
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Samsung fax machine SF-365TP
Before diagnose the problem please turn off the Machine.
Check all sensor if they have dust then clean it.
Close properly the cover.
Sep 15, 2008 | Samsung Office Equipment & Supplies
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Fax machine problems
Unplug the device from the AC power for about 30 minutes to allow it to reset the circuity.
Hope this helps.
Machine keeps saying job waiting
turn of the unit....
press the stop button hold it
turn up the power
wait till 3 sec.
then release the stop button
that should clear the machine.
May 01, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Paper jumped problem
Do you mean jammed?
Usually they don't lie. A piece of paper is somewhere.
Apr 09, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Dialling out!
Hi make sure that you don't need a prefix number i.e. a 9 to dial a outside line. The best test is to plug a normal phone into the socket and call someone from that line. If the same problem is still there then it is a line problem if not check within the machine menu that under TTI or call settings that there is no prefix number installed. If there is set the machine so it doesn't need a prefix.
I hope this helps you
Thanks J
Jan 06, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-340 Plain Paper Inkjet Fax Logo
135 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
