Question about Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready LCD Television
Installing tv in boat
I have a sharp aquos 15 inch, ,when i install this in the boat do I need to use the supplied 110 to 12 volt converter? or can i connect direct to 12 volt? if so how do i wire it? thanks
    President:
  • 3,130 Answers
You can But I would not connect it directly unless I had a regulator or isolation device between the set and the boats power. if your boat has 110 volt capability just be safe and use the adaptor.
Posted on Sep 15, 2006
Sharp tv resolution not supported
I often use IDealshare VideoGo to convert all Sharp TV unsupported video file, like MKV, MP4, AVI, WMV, MOV, FLV, ASF, 3GP, AVCHD, MPG, MPEG, WEBM, etc to Sharp TV supported one and also convert any video format to another one, like converting MKV to MP4 etc.
Jul 09, 2012 | Sharp Aquos LC40LE830U 40-inch 1080p 120Hz...
Have a red blinking light on tv tv does not turn on
Normally one red blinking power indicator means your television needs a main board and or a power supply. The television would need to be evaluated and if you need a power supply only perhaps the service provider can rebuild it for less than $200. If the television needs a main board perhaps Sharp will work with you if you have an estimate. If you really have an aquos television 46 inches or greater you can get assistance at 877-332-7867
Aug 19, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
The main power transistor in the power supply appears to have failed. It has also blown the fuse. Not a job for the DIY'er unless you have serious electronics experience.
Mar 08, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Oct 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Jul 24, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No power to tv after unplugging and replugging
either the fuse is burnt out inside or the the problem is the power supply board. You can remove the back cover to see if the fuse is good or not.
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power cable problem for SHARP AQUOS TV 42 inch
The voltage rating of the cable is not a problem. For all home appliances, including TV sets, the voltage rating of the power cable is supposed to be up in the 600 Volt to 1000 Volt range depending on the particular manufacture of the cable. This is not an issue. I have never seen a home appliance that could handle more than 240 VAC.
As for the Amperage rating of cable, it is more than adequate for the appliance that the cable is sold for. The 220 Volt appliances use about 1/2 the amperage that their equivelent 120 Volt appliances use. This is because the wattage for the power consumption is normaly constant.
The power cable is not a factor here. If the power supply in the TV can take the 220 VAC, and the 50 Hz power line frequency then there are no problems from that point.
Jerry G.
May 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-15S1U-S 15 in. EDTV-Ready LCD Television Logo
786 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
