Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Installation Error I recently re-installed Windows XP SP2 in my computer but halfway through, it gives me an error message saying " Installation Failed:D:\I386\asms" and "Error Message: The Parameter is incorrect" also "One of the components that windows need to continue setup could not be installed". Can you help me about it? Edison SBMA, Philippines
    Sergeant:
    Champion:
  • 275 Answers
There could be either one of the 3 parts which is giving u this error
1) instalation cd ...(try installing from a different cd )
2) cd/dvd drive ( try with a different drive )
3) faulty memory card
mostly this issue is being created by faulty memory card if possible try that first
Posted on Oct 31, 2008
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Java installation problem
How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks..
Error: 25099 during Java installation This article applies to:
  • Platform(s): Windows 2000 , Windows XP , Vista , Windows 2003
  • Browser(s): All Browsers
  • Java version(s): 6.0 , 6u10+
SYMPTOMS
While Java installation is in progress, a message box with the following error is displayed:
Error 25099. Unzipping core files failed.
CAUSE
The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Nov 08, 2009 | Computers & Internet
XP Installation and win32k.sys
hi,
this problem is occured due to corrupt or scratched disk.
u need to install XP with new bootable disk.
Sep 18, 2009 | Microsoft Windows XP Professional for PC
SP33867 is not installing on windows XP sp3
Windows Error 0×80040707 - Caused by InstallShield and Windows SP2 DEP
Posted Service Packs & Hotfixes, Software - Third Party Programs, Windows Desktop Fixes on Saturday, March 11th, 2006.
From Windows 95 to Windows XP & Vista the “Unhandled Exception 0×80040707′ error message, pictured below, typically occurs during the installation or update of PC software. The error code is typically associated with the installation program InstallShield, which software vendors wrap around their own software packages so they can install to Windows without interferring with existing software. The error was typically associated with the paths to Shell folders in Windows (ie: the Desktop, Programs, and Startup Menu folders in a user’s or the “All Users” profiles) - there is a detailed description of changing or recreating these paths at InstallShield’s site.
The 0×80040707 error code has become more common recently, as the Data Execution Prevention (DEP) controls (screenshot link) installed by Windows XP SP2 also interfere with InstallShield’s operations and can block its access to the Windows shell folders mentioned earlier. If your shell folder paths are all correct, the likely culprit of the error is Windows’ DEP and these steps should resolve the issue:
Find the primary installation file for the program you were installing. If it’s not a single-file installer it’s usually “setup.exe” on a CD, but you can either check the AUTORUN.INF file to see what program it’s calling or dig through the folders on the CD (/bin/, /eng/, and /driver/ are common folders where the true installer program is nested when the setup.exe is just a fancy GUI program).
Right-click the installation program and select “Run As…”. If it doesn’t show up the then file may not be an executable > start over at step #1 and look for other files.
Uncheck the “Protect My Computer And Data From Unauthorized Activity” box, this deactivates DEP for this executable and its child processes, and click the “OK” button.
Jun 01, 2009 | HP 530 Notebook
I recently discovered that Anytime I start my Toshiba Saetelite A105-S3611 laptop/notebook with windows Xp SP2, there is a message: ?Toshiba Power Saver?, A fatal error has occurred, this program will be...
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
May 05, 2009 | Computers & Internet
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Error during babel initialisation during execution of bad boys 2
Everyone, I have found the solution to this. The simple thing is this game was never made to run on Windows Vista or above.
You can fix this easily though - go to your desktop and you should see the Bad Boys II launcher, right click and then go to properties. Then click on the compatibility tab and tick the box that says "Run this program in compatibility mode" and choose Windows XP.
Problem solved, if you want to thank me visit, daily-porn.co.uk to make some easy money.
Mar 31, 2009 | Video Game Consoles & Games
Motherboard and cpu
thanks for the details supplied although I believe you're missing some details
1. are you trying to install the whole operating system (windows xp sp2) or only the SP2 for windows xp?
2. if you are trying to install the os (windows xp sp2) is this a clean installation (recommended) or you are trying to upgrade from a previous operating system (9x, nt, 2000)??
10. are you getting a blue screen with this message?? in what part of your installation??: the DRIVER_IRQL_NOT_LESS_OR_EQUAL or PAGE_FAULT_IN_NON PAGE_AREA message is something I'm assuming you're getting on a blue screen before the computer shuts down on you (please confirm if this is accurate)
2. if you answered yes to the previous question what we need is the line at the bottom portion of the blue screen where you see something like 0x000000?? (0x00000......
if possible get this information and post it here. this information is called a stop error (the blue screen is also called a stop error screen or blue screen of dead (BSOD) as is coloquially known) the code will give you/us a better idea of where the problem lies.. but taking an educated guess you may have driver problem creating some type of issues.
in the mean time my suggestions are the following:
a. while you get and post the information required above is, if you're trying to install the service pack 2 on a working xp installation, is to try to install the SP2 by only having the basic peripherials plugged into your system. (keyboard, mouse and obviously your monitor) and reattempt the sp2 installation.
b. if you're trying to install the operating system (either clean install or not) make sure your windows xp sp2 copy is a good copy (hopefully will be a valid copy of the os) if not you can always run into problems now or at a later time.
c. if you're trying to install the os and want to make sure your system/hardware configuration is appropiate for the installation this are your options:
1. check the HCL online (if you have a previous installation you are trying to upgrade to xp)
http://winqual.microsoft.com/HCL/Default.aspx?m=x
2. if you have a previous windows installation you can also use the upgrade tool to confirm if you have what you need to put windows xp on your system.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q307726
2. if you have don't have an internet connection you can use the windows xp cd that you have to confirm whether you have what it's required in terms of hardware:
Pop the cd into your CD drive. Close the screen if auto run launches and open Run from the Start Menu. Type in D:winnt32.exe /checkupgradeonly, substituting the drive letter of your CD-ROM for D if it’s different. This will launch the Microsoft Windows Upgrade Advisor that will identify any hardware and software upgrade incompatibilities.
Oct 07, 2008 | Computers & Internet
Recovery CD-Image Error: Installing windows xp Home SP2
hope your 4 cd is error....plz ask your near vender or microsoft.com about to your sp 2 .
Mar 18, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
252 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
