Question about Epson Perfection 3490 Flatbed Scanner
Program won't completely install
I've tried seven ways to Sunday to install the creativity suite for this scanner. The "Attach to Email" part installs correctly, but the other three utilities get a "component transfer error". I've tried completely uninstalling the program, but the Attach to email part will not completely uninstall either using uninstall, Add/remove programs or deleting from registry. Status bar goes halfway across then just disappears.
Attached are screen shots of error messages on installation.
I've contacted Epson and all they say is reinstall my operating system. Running Windows xp home, Dell Dimension 8200, connected via usb. I am owner/administrator (the ONLY one) since build date June 2002.
I've looked all over the net for a solution but have found nothing as to the cause or solution.
Help?
  • 488 Answers
What i can suggest is that you download the latest drivers from the epson website,also check if your operating system is uptodate with the latest patches and updates..
see if this helps:
One overlooked reason for getting access denied and/or other problems when installing software is the existence of a file that needs to be replaced but can't be due to a read-only attribute. This most often occurs in the %SystemRoot% directory and its' sub-directories. To display the files in your NT directory that have the read-only attribute, type:
dir %systemroot%\*.* /ar /s
You can remove the read-only attribute from a file by using the attrib command. To remove the read-only attribute from all files in the NT directory and sub-directories, type:
attrib -r %systemroot%\*.* /s i the run command..hope it helps!
Posted on Oct 31, 2008
Cc4 205 00000012
Sir/Madam
To solve this issue, please install the latest scanner driver. If you use MFL-Pro Suite Software,
  1. Click Start => Control Panel => Programs => Programs and Features.
  2. Select Brother MFL-Pro Suite from the list, click Uninstall and follow the on screen instructions.
  3. Once the uninstallation is completed, disconnect the interface cable and restart the PC.
If you do not use MFL-Pro Suite Software,
Make a temporary folder on your HDD to save the downloaded self-extracting file, e.g. C:\bront
Please click here to download the uninstall tool to remove the drivers.
Once downloading is completed, double click the downloaded file to extract it.
"ZIP Self Decompression" appears. Click DECOMPRESS.
"The decompression process was successful." will appear. Click OK.
A folder will be created in the temporary folder created in Step 1.
Open the folder and double click DelInf32.exe. "Brother MFC Uninstaller" dialog box will appear.
Select your model and click OK.
"Complete" will appear. Click OK.
Click here to download the latest "WHQL certified Printer Driver and Scanner Driver", and install it following the Install Instructions.
Or
Still Having Problem Then Go To Brother Printer Official Website :
When trying to scan using the Brother ControlCenter3 on Wind Brother
Or
Stll Having Brother Printer Problem Then follow Us For On:
Brother Printer Support
Jan 20, 2014 | Brother Office Equipment & Supplies
Crossposted:
For me some of applications what You have installed, corrupt windows system libraries, that is why windows is hanging/crashing while trying to open such us applications, If You have an original Install Disk, try with them, and if You still need them programs installed do it one by one doing clean restart of pc before You will install another one then You will find out witch one is causing problems for You.
Hope You will solve it.
Jun 03, 2013 | Sony VAIO Computers & Internet
I'm having trouble downloading CS6 Master Collection.
Hello
Try using The Adobe Creative Suite Cleaner Tool
It helps resolving installation problems for Adobe Creative Suite 6.
Before you start
  1. Back up all files stored in Adobe product directories. This may include custom plug-ins or profiles you have installed.
  2. Be sure to read ReadMeFirst.pdf, which is downloaded with the Creative Suite Cleaner Tool.
Check this Link Adobe Creative Suite Cleaner Tool
Try reinstalling the Software
Tejodhar
Mar 21, 2013 | Adobe Master Collection CS6
I've a htc trophy. i need pc suite for my htc trophy.how can i get or download it?
Here is Download link HTC 7 Trophy Sync version 3.0 driver for connect to PC Windows. Here also give information about how to install this software. The software HTC Sync PC Suite are ready to download. Please follow the instruction bellow :
  1. Please click Download below to download HTC 7 Trophy Sync to your PC.
  2. Run file setup to install it to your PC.
  3. Follow the Install Shield Wizard to finish the installation.(Suggestion: Please close all running programs and temporarily exit your anti-virus program when you install the HTC Sync).
  4. Select the "Complete" Setup Type for faster and easier installation process, and then press "Install" to begin the installation. (For advanced users you could choose "Custom" to change the pre-defined shortcuts and the installed application folder path by your own.)
  5. After you saw the Install Shield Wizard Completed, please press "Finish" to exit the Wizard.
  6. Use the USB cable to connect your phone to the PC
  7. Now you can start HTC Sync.
http://mustikamax.com/2011/03/09/download-htc-7-trophy-sync-version-3-0-driver-pc-suite-for-windows/
May 09, 2011 | HTC 7 Trophy Cell Phone
Hi this is from chennai... i have hp scanjet g3110 .. it was worked good till before october.. now the software didnt open..i had installed the software many times.. no response... i had installed updated...
first before installing any software turn off you anti-virus program.
next uninstall the scanners software completly before installing a new copy to do this just goto control panel select program and features. then select the hp program for the scanner and double click on uninstall.
then do the following:
1) disconect the scanner from the computer.
2) insert the disk that came with the scanner.
3) attach scanner and allow it to find new driver.
4) scanner should work.
if this does not help then email me at rafurmanekjr@hotmail.com and i will log into microsoft messenger, and try to assist you live ok
Rob
Nov 25, 2010 | HP Scanjet G3110 Flatbed Scanner
How can i install driver for benq scanner 4300?
Hi Malik Nasir,
How are you? I hope everything is going well. My friend, first install its scanner's software without attach scanner. After the complete installation, attach scanner with your PC, then it will be detect automatically and then it will detect drivers and the issue will be resolve.
After complete installation take a reboot either software not required.
Good Luck.
May 13, 2010 | BenQ Scan to Web 4300U Flatbed Scanner
How do i scan documents so I can email them?
just place your paper document in the scanner, cover it, then press the SCAN button in your scanner device. Another way to do it is to open your scanner program installed with your printer. Then make sure to "Scan to File" so that you can save your scanned document to file and attach to emails or whatever.
Regards!
Jul 13, 2009 | Canon Pixma MP500 All-In-One InkJet...
How do i load photos on Motorola MOTO? W755 is the sd card the only way to do this? I' ve tried tools program ,only good for music.
Download Motorola Phone Tools v5.0.5. When installed it will automatically update to the newest version. This new version will transfer photos.
Go to the following website:
http://motoroladownloads.webs.com
Sign up to enter the site. (It's as easy as 1-2-3)
As a member, you can then download the Motorola Phone Tools (PC Suite) for your PC for free.
**Make sure you download the USB Drivers, too.
The download for the PC Suite is in .zip format. You'll need to unzip it to a new folder. (You can create a new folder on your desktop)
After unzipping the file to the new folder, double click on it to open > locate the >>
Setup884ac5e.jpg icon and double click on it.
This will install Motorola Phone Tools (PC Suite) on your PC.
Start the Phone Tools Program by double clicking on the icon on your desktop.
Download the Data Cable/Modem drivers and attach your phone to your PC with a USB data cable.
(You may also be able to use Bluetooth)
The PC Suite will include all of your options on the left hand side. <...>
Feb 22, 2009 | Motorola Mobility RAZR V3
Creative WebCam Instant - Install program
If it is creative webcam with model no. vf 00090 I have a cd installer for that.
Jul 07, 2008 | Creative Labs WebCam PRO
Epson Perfection 3490 Flatbed Scanner Logo
311 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
