Question about Radio Communications
VHF Radios I am wondering whether you can use 2 VHF radios through a single antenna. If you do... If one is transmitting from the Bridge, can the one in the Crew Mess hear both sides of the transmission? We have limited space on the mast so this is the reason for sharing antennas. Any advice gratefully accepted Thanks Richard
    Brigadier General:
  • 6,966 Answers
Technically no. The reason is the receiver end would be overloaded with the signal from whichever is transmitting specially if on the same frequency. This could only be done if the frequencies of the two radios are largely apart and a duplexer/cavity filter is used. An alternative is to have a small local repeater, a single common antenna for both receive and transmit and a row of cavity filters. A low power portable anywhere in the vessel would be electronically repeated by the repeater to be received by any low power portable again anywhere in the vessel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
I have a uniden vhf radio that transmits but won't receive
send it for repair
Uniden - Online Repair Form - Uniden Repair Center - Uniden Americahttps://repair.uniden.com/repairInstruct.cfmRepair Procedure -Brand New Products. Marine Radios=3yr Warranty, Scanner Radios=1yr Warranty. GPS System=1yr Warranty, Digital Camera=1yr. Warranty.
uniden vhf radio Google Search
Jun 24, 2017 | Uniden Radio Communications
Have vhf marine radio can transmit but can hear other person have even tried another vhf same problem
Not likely that you get two that won't receive. Check your Antenna sounds like there is something blocking the signal at the frequency you are receiving on. If you have used this Antenna successfully before then it is the Radios. If not reposition the Antenna and try to gain a signal. As VHF follows the lay of the land it is easier to pick up than UHF and that rules out the line of sight transmission so something is blocking your incoming signal if it is not your Antenna. It has been years since I worked on LMR's but seems like I remember some Antenna's having filters in them which had to be tuned. I'm not sure about that one it has been 30 years since I worked on the Radios. Put a Watt meter on your Radio and see if it is putting out enough Wattage to get out and use a RF Probe to check the Antenna while it is keyed down to transmit. If these are good then something is deflecting your signal and you definitely need to relocate your Antenna. This is what I would try and some of the things we did for the same problem. As you know and I said earlier VHF Signals follow the lay of the land and for a long time that was all the THP [Tennessee Highway Patrol] had in their cars. We've got a few hills in TN as you might already know. Now they use cell phones and text while driving.
Hope this is helpful and if I can be of any further assistance please feel free to contact me.
Col. Dana Gillespie
May 04, 2014 | Boating
I have 4 vertex VH-160 radios, two of them have stopped transmitting, all have been dowlaoded witht he same frequencies. Batteries are good. Whe transmit buton is pushed, the is one beep then nothing. ...
The VX 160's may have bad oscillators. It is not user repairable. The simple thing to check are the antennas. Vertex radios are very susceptible to broken antennas and will not transmit. This is true of Uhf and Vhf. Replace one and try it on all the radios. Never transmit without a antenna. It can cause the PA in the radios to fail.
Jan 06, 2014 | Vertex Radio Communications
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Oct 06, 2012 | Uniden Solara DSC VHF Marine Radio
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
Vhf 340 walkie-talkie radio you cannot transmit but you can receive effectively. I open the radio but no sign of any burn.I try the radio in all the channels is the same response. thanks. we use them in...
You may have a bad antenna. What happens is a lot of guys carry their radios around by the antenna, inside the connection to the antenna is weak and can crack at the solder joint, thus opening up the antenna circuit and prevent you from transmitting any power out. Our Motorola hand helds have this problem, they are weak at the antenna connector and guys swing them around by the antenna end up breaking them.
Your next problem is that if the radios have been used often enough with a faulty antenna circuit, your final amplifiers are probably toast from transmitting into an open antenna circuit, causing all the power to be reflected back into the radio and burning out the final amplifiers
Sep 15, 2009 | Motorola Walkie Talkies 2-Way Radio
Navman VHF 7100 Radio neither receiving nor transmitting
I would suggest checking your antenna/coax connector. I am not sure what kind of antenna or ,mount you are using but I would suspect it being something in the antenna. Most radios are designed to not transmit if the antenna is broke or not connected at all. When you say bent do you mean metal bent or bent at the base? So that would be where I start. Can you try a different antenna? Hope you track it down. N5ARK
Aug 10, 2009 | Navman Tracker 5600 GPS Receiver
Cannot recieve or transmitt signal... friend has one and lives about 1-2 miles away from me... we try to communicat but cant find any transmission... please help
Just wondering what type of antenna and Cable are you Using? Also When you press the Microphone do you see the needle on the radio Move? Also if you whistle does the Needle Move? If neither Possibly a bad Microphone. Does your friend Notice a signal when you press the Microphone? If so and no voice is being transmitted again it could be the Mic. Then again it could just be bad Coax Cable. Hope this shed some light.
Jul 05, 2009 | Raytheon VHF 53 CB Radio
Looking to build a two way radio system.
You will have to have a vehiclular repeater that is in another band than the mobile so if your portable hand held radios are on UHF then I would advise a VHF high band repeater set up.
It will have to be a cross band setup meaning it will recieve UHF and transmit on VHF and also the opposite direction.
It will have to be programmed with CTCSS or PL of some kind to avoid interference and don't forget it will need to be FCC licensed for those frequencies if it is in the Business band.
Some mobile radios can be wired up through a mini controller and run that way if it is compatible.
Apr 28, 2009 | Motorola For SP50 7.5v 1500mAh NiCd...
VHF transmit power
Hi, It is not typical but neither is there a problem with the radio. Transmit Power output is loosely dependent on the: 1. Frequency or channel you are transmitting. Normally, Marine Band VHF are calibrated for max (25 in your radio) at Ch16 or 156.800Mhz; 2. If the SWR of the antenna is not a flat 1.0, power tends to go down; 3. After some time, the TX side of the radio needs to be re-calibrated; 4. Power Supply - some radios will push max output only when powered with 13.8 and tends to go down when used with 12 volts. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Garmin VHF-725 2-Way Radio
Radio Communications Logo
75 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
