Question about Motorola Mobility RAZR V3
My Bluetooth will not power on.
Hey there, I've tried everything but i cant fix this. The bluetooth will not power on on the phone. Please help....I have a bluetooth device Motorola H350 and now i'm out of options. This would be my last restore. Thanks in advance Olla
Still trying to fix problem would keep you posted
Posted on Sep 23, 2006
Cant get internet on my itouch from my X3 via bluetooth
first of all get the latest software. i think the latest one is ovi and not the nokia pc suiteafter having it make sure you are using the correct settings in your mobile then try to connect itif it doesn't connect call your customer care and tell themthere are few networks for which the settings in ovi must be entered manuallyas you have not provided your service provider name i cant help you out much
Nov 24, 2011 | Nokia X3 Cell Phone
Hey I using micromax A60, the problem i am facing is that when try to check balance(tata dococmo) by inputting *111#.It does'nt show me the balance.Instead of this,a scrolling symbol is seen. Also when i...
I cant help u wit balance checking but I can hlp wit Bluetooth issue. download Bluetooth file `software from Marky is very good u an and n ecieve files...
Feb 15, 2011 | Cell Phones
Bluetooth on LG Shine CU720
make sure your visability is on, the bluetooth function is on (on the phone) also make sure your bluetooth is powered on. as far as pairing with another phone is concerned, is the phone the same provider? you cannot pair with different providers.
May 18, 2009 | LG Shine CU720 Cellular Phone
W700i mobile have less power for bluetooth
Hey buddy this is the problem with your bluetooth antenna. I think you have given the phone for service in some local service centres. Your bluetooth antenna is misplaced. Just give it to any authorized service centres of sony ericsson. They will fix it. If it is lost you have to pay rs 550/- for a new one
Dec 25, 2008 | Sony Ericsson W700i Cellular Phone
Bluetooth operation problem
you need to go technician then ask them to reformat your n70 phone,so that it will work well.
Nov 22, 2008 | Nokia N70 Cellular Phone
Bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Sep 16, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth 350
It might be the pairing has drifted slightly. I would try repairing again. It certainly cant hurt anything.
Aug 20, 2008 | Jabra BT350 Bluetooth Headset Headset
Cant pair my bluetooth
To identify where the problem is, try connecting another bluetooth device (like another phone, or a bluetooth headset). The other device will most likely connect. If it does, try contacting the manufacturer of the dongle, they will probably have a simple solution to fix it.
If it does not connect to another device, try deleting the bluetooth devices stored in phone (especially ones you dont use, but you may need to delete more/all depending on the situation) and add then. This fixes connection issues the majority of the time with very little trouble since rebonding what you need later is a simple task.
May 17, 2008 | HTC PPC-6800 Smartphone
Sending data /images / mp3 via bluetooth to other mobiles
it will not show u sending via bluetooth but it sends as beaming the file
Dec 12, 2007 | i-mate JAQ Pocket PC
MOBILE PHONE NOKIA
Pairing This was the second Bluetooth device I?ve used, and I had the headset paired in under 60 seconds once I had deciphered the instructions in the manual. When you press the call control and multifunction control buttons on the headset simultaneously, the M2500 goes into pairing mode. The standard way to get the Treo to pair is to click on the Bluetooth icon and basically follow the prompts: Turn Bluetooth on, make the device ?discoverable,? click on ?set up devices? and then ?Handsfree setup,? and the Treo will find the Plantronics headset. Once you?ve set up one Bluetooth device, you?re a pro. The only thing you need to know is the combination of buttons that puts a device into pairing mode. However, with the Plantronics M2500, I discovered an even easier method. Simply power up the Bluetooth headset while the Treo is on and you will be immediately prompted for the passcode, four zeros, if the devices are not paired. How cool is that? It saves many steps.
Jan 28, 2007 | Plantronics M2500 Consumer Headset
Motorola Mobility RAZR V3 Logo
78 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
