Question about Toshiba Satellite A135-S4527 Notebook
Re: to your charger problem
Hello, I accidentally hit enter in the middle of trying to write you the answer to your question hence the weird reply. I have since answered it correctly. Thank you.
Why did it shut off and doesn't restart?
Is it recharging properly, might not be charged and is auto shutting down to save data.
Check your charger is working and the connection to the tab is good.
Bad fitting USB can cause failed charge.
Apr 04, 2016 | Samsung Galaxy Tab Tablet PC
I accidentally let my phone die and now it will not turn on. I have charged it for over a day and it still will not turn on. The charger is fine though.
Try removing your battery and sim card if you have one for about ten minutes. Then put it all back together and see if that worked.
If my answered help give me four thumbs as thanks!!
Aug 28, 2011 | Nokia 6350 Cell Phone
My Blackberry shows me "Battery
It seems this problem is kinda weird,i heard this problem to my co-worker,searching lead on the internet but no one can answer and testify correctly, Now this is what he do.
* replace the battery
* replace charger
* clean battery terminal and charging outlet
* update the phone firmware,might be a software issue. UPDATE FIRMWARE
and the result,still the same...
Now he detach the battery on the phone and went out of work,on the next day,he check and put the battery back,then phone works ok.
It's so weird but the luck is their,well i'll be advising you to go beyond that luck as well as the given procedure,it might be your lucky day.i am not saying this is reliable,but if you hit this,save money and learn extra ordinary problem.
Otherwise, need to consult service center,they might have better or best idea to make it works.
Aug 08, 2011 | RIM Cell Phones
D-Link DS-G604T abnormal Flashing Leds
hello,
Please do the following on the pc with the wired card not working:
Click on start, then hit RUN, then type in it: cmd
and hit enter.
in the prompt that you got, type: ping 127.0.0.1
If you get a successful reply in the form of the below text, then your network card is working, if not, then the network card is burnt from the thunder storm.
Successful reply sample:
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Mar 14, 2009 | D-Link DSL-G604T Wireless Router
Tx1320us cracked lcd
If you can elaborate on the exact issue, I will surely try to help.
FYI,
As TX1320us is new notebook, I guess it is one year below model and it should be under warranty.
If you have any issues with the screen, then you can get replacement from HP.
If it is accidental damage, then it won't be covered under warranty. If you have purchased Accidental Damage Package from HP, then all broken and other damages will be covered ADP.
Anyhow, reply if you need any information in this regard.
I will be happy to answer.
Aug 08, 2008 | Computers & Internet
Dear Sir/Madam I have a very very old personal organiser ZQ-1250 and I accidentally deleted all my stored information in terms of address and telephone numbers which I am desperate to retrieve, hence this...
Take out the Batteries. Then Take out the Small Backup Battery. It is about the size of a 5 cent coin. Then reinstall both batteries and try again to enter your data.
Apr 18, 2008 | RIM BlackBerry Pearl 8100
V chip codes
I think you hit "0000" then enter. I'm not positive but this maybe the answer. Give it a try and let me know if it worked. Thanks and happy tv'ing. Jay
Jan 21, 2008 | Mitsubishi WS-55807 TV
Acer 3003lci will not boot up.
sounds like locking up on boot, hence why nothing happens when you hit F2, try tapping F2 as soon as you push power button, if still hanging, you may need to take it to get looked at, could be a number of things causing it to lock up
Dec 11, 2007 | Acer Aspire 3003LCi Notebook
Battery charging
Sony ericsson phones have a weird way of diconnecting the charger from the phone, u have to pull up at a 45-50 degree angle to release the cable, perhaps you have accidentally twisted the pins inside the actual phone, or the may be dust obstructing the pins in the phones socket
Jul 27, 2007 | Sony Ericsson T630
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
