Question about Intel D845GVSR Motherboard
Power failure power ic problem;correct power is not flowing in the board so motherboard will not boot
  • 1 more comment
  • cndesu Nov 06, 2008
    There is a red light glowing on hard disk. When all CD Rom drive, hard disk, floppy drive removed from the board red light is gone but system is not booting and video screen is blank.
  • allanl Nov 11, 2008
    I have a green led on the motherboard, all memory and connectors appear to be OK.
    Nothing happens when I try to power it up.
  • Frank
    Frank May 11, 2010
    check your power connector, make sure it is in correct orientation, and not miss pins.
    what about the memories??
    are they comparable to the motherboard and the CPU???
  • 24 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
100
Posted on Mar 13, 2009
  • 35 Answers
Maybe the motherboard maybe be damaged butb even if the board is not functioning properly,the cooling fan and the led`s will be working
Posted on Nov 11, 2008
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
Dell xps 710 motherboard replaced with 700 motherboard but it does not boot
This could be any number of problems. First start with hardware. Is everything seated and connected correctly? Are the hard drives installed correctly. Are the power on pins on the board set correctly or pinned at all? Is the ram the correct ram?
Check the hard drives, are they functional, do they boot with other computers?
Use a volt meter and check that the power supply is producing the correct voltages on all the connectors and rails.
If that all checks out, it might be a bios error. Check your boot load order and if the motherboard is detecting the hard drives, check that the correct bios settings for OS management are in place as this is a server. Is the RAM power settings (voltage) and speed correctly selected? Will the computer boot from optical drive using a live CD? Will it boot from a USB live OS (like Ubuntu)?
Since it's not booting, you may not have compatible hardware or damaged hardware. The OS that's installed on the hard drives may not be able to load on the new (older model) motherboard due to driver incompatibility.
Oct 13, 2013 | Intel Server Board SE7501BR2 Motherboard
In asus P5GL-MX mother board the power supply regulator ic 2 piece has been damaged (short) how would i know plz help me
Hi if the regulator ic has been damaged in your power supply even you replace that there are some electronic component where also damage because the ic will not damage where there is no over voltage flow on it. This means there are some resistor or a transistor is also shorted it advisable to replace a new one than to repair your power supply. Because even you repaired it the performance and the life span of your power supply is not stable. So it better to replace a new one.
Jul 14, 2011 | ASUS P5GL-MX Motherboard
My ASUS P5QL Pro motherboard will not boot up correctly quite often. I have swapped RAM, power supple, video cards and i made no difference. the last time i pulled the bios battery and the bios chip,...
i had just solved this problem yesterday, there this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on motherboard EPU asp0800 near the CPU Socket
2.Press the IC with finger,at the same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please rechecked step 4
Sep 24, 2010 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Turns on, cd light comes on but cpu does not boot and light does not come on, the monitor says "no signal" . Cpu dpes not shut off at the button anymore. I have to unplug it to turn it off. HELP! By the...
You should get it repaired. That is likely a power supply failure. Yes, I see you have power, but I still say power supply, because there are 2 types of power: There is Motherboard power and there is CPU power. If CPU power is not correctly flowing, the CPU will not activate. If the CPU is not active, the board will not process any information, even though the board is receiving power. Power supplies are not hard to replace and are usually about 40 bucks
Oct 01, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Hi,my motherboard in not booting after connecting new power supply,power supply is OK,motherboard lights are on.But when start button is pressed its not showing anything
Try this site //www.dealextreme.com/.Repair tools cheap !! You need PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Price: $2.57 free-shipping_small.gif PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card costs $2.57 and free shipping.Great company.need help majortom350@yahoo.com PC Motherboard Repair/Troubleshoot Boot-Failure Diagnostic PCI Card
Aug 22, 2009 | Computers & Internet
Can not save current bois version: P4S8X-X BOOT BLOCK
I sent my system with intel desktop mother board and IntelPentium 4 processor to a service center for repairng. it cannot take key board and dont step into bios. but the service centre damaged my board and processor now. so how can iknow the prcessor original?
Jan 07, 2009 | ASUS P4S8X-X Motherboard
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
Boot failure
samuel,
if you don't here ok beep or any error beep:
  1. First check out speaker is connected properly to motherboard.
  2. Remove all component from motherboard like HDD,FDD, RAM etc..
  3. Just put only processor to your board and power-up
  4. There must be a long beep for missing RAM, if not means you have problem in Motherboard or CPU. Try out another board and another CPU to find out which one is faulty.
  5. If you got missing RAM beep, then power-off and add RAM. Then power-up there must be ok beep (only one beep) or missing RAM beep. If missing RAM beep, then your RAM might be faulty try to clean the connection point with pencil earaser and try out again. If no success then try with another RAM.
I think this will help you.
Please post your feed-back. Or ask me if any question.....
Gud luck
Iqbal
Apr 21, 2008 | Computers & Internet
Intel D845GVSR Motherboard Logo
203 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
