Question about Kenwood FreeTalk XL TK-3101 (15 Channels) 2-Way Radio
Yaesu Ft-60R with Kenwood TK-3107
I am using Yaesu FT-60R with Kenwood TK-3107. It seems that I can receive from TK-3107, loud n clear, but when I transmitted from my FT-60R, Kenwood TK-3107 could received the signal but the voice could not get through. I was told that Kenwood TK-3107 has CTCSS/DCS/DQT/QT.. I can't find the correct tone(from web) to get through the CTCSS
  • tang9w2fyo Oct 31, 2008
    Hi Benimur,
    Thank you and really appreciate your advice. I tried without CTCSS to tune to the correct frequency. However, the Kenwood TK-3107 came with pre-programmed CTCSS from the factory. I just need to find the correct tone for TK-3107 to break the CTCSS.
    Thanks a lot..the problem is solved..the manual really helpful
  • 3 Answers
Ok guys!! i have gold for your prob huhuh
go to this website and u can get anything about all model TK
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
Posted on Feb 27, 2010
    Brigadier General:
  • 6,966 Answers
Initially and the simplest probably would be to use the units without enabling the CTCSS or any form of encoding (turn this feature OFF). In the meantime, will check the specs and post if anything concrete comes up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Oct 31, 2008
    Hi again,
    The closest I can get is the user's manual for a TK3100. Page 11 details QT codes with their corresponding standard signaling codes from the original 38 PL tones as well as their equivalent frequency in Hz. Since to my knowledge the TK3100 would require a PC interface and a software (KPG-22 & KPG55D) to change most settings, it may be that the Yaesu FT-60R be made to change and follow what the Kenwoods are using.
    Hope that this work for you. Regards from DU land.
  • Les Finlay
    Les Finlay Sep 22, 2017
    Very old thread so not expecting a response. But how do you turn off CTCSS?
  • Les Finlay
How do i reset a kenwood tk3160 to the default settings.
SUPER ODD...
I scoured your KENWOOD TK3160 Users Manual and a RESET process is NOT shown at all!? Find the link below...
They DO mention Programming Software and THAT may be your BEST solution?
You also want to gracefully reprogram your transceiver and SOFTWARE is your best choice for that too!
Your programming cable is about $5.35 FOR TWO on eBay... I KNOW!...
Anthony
http://manual.kenwood.com/en_contents/attachDownload/1000011002
2xUSB Programming Cable Adapter for Kenwood TK 3102 TK 3107 TK 3118 TK...
Dec 02, 2017 | Kenwood Radio Communications
Tk-3107 but can't talk to my friends who already used tk-3107
there are to many options to solve, And to few information given by you
1 first turn on the sound knob (most likely)
2 read the channels of you're equipment and those of you're friends
software is all over or use an old radioscanner or freq counter.
3 put new software in all the equipmant. Easiest way
Oct 21, 2013 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Dead Yaesu FT60R
There is probably an internal fuse which has blown. Send it to the Yaesu service center for repair. They're reasonable and will do good work...
Jun 27, 2013 | Yaesu Ft-60r Dual Band Handheld Vhf / Uhf...
I have a yaesu ft-736r with no audio
Hi Jermaine,
It transmits, but no receive, are you sure, have you tried playing around with the volume control?
If, so did that make any crackling noise? If so, then this is due to lack of use of the volume control, many radios, including the old transistors with dials, would make crackling sounds when you adjusted the volume, and as I say, this is due to lack of use, So if this is the case and to get your receiving, turn the volume control up & down fully for a few minutes and while doing so your radio might receive a transmission that will be loud, quiet, loud, quiet, etc., as you play with the knob.
Keep doing so until all crackling has disapeared.
Do this often as possible when firing up your radio for the day, the more use these controls get, the better.
I hope this has answered your query.
Cheers,
Peter
May 29, 2012 | Yaesu FT-736R
Yaesu ft 416 ver a2 need reset to get extended receive
You may find detailed instructions for this on www.mods.dk
Jul 03, 2011 | Vertex FNB-27SM,...
Kenwood FreeTalk XL TK-3101 (15 Channels) 2-Way Radio Logo
1,713 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
