Question about Nokia 6288 Cellular Phone
Phone Memory Problem
I cant receive any messages and I have reset my user settings, I cant download any applications or anything (Pics or Music) on the phones memory it says that I have no memory available and there is 6 mb onboard memory and I cant receive messages because of the fact that the phone tells me that there is not enough space. I have reset the phone and updated the software as well.
  • euries Nov 01, 2008
    Any other solutions possible for thios problem,thanks man for trying
Could be a problem of ur Memory Card or internal memory if its the memory card u should try replacing it if its internal memory only u should take it to a mobile shop...
Posted on Oct 31, 2008
Hi Mtyy nokia c5-03 messaging is not working, web applications , it says sim memory full , but the phone memory free 308.0 kb . i dont receive any messages >.< . i dont know what im gonna do . I Cant text...
Stop whining and log into Nokia Suite (free).. Download it to your com if you haven*t. - Then you have the interface to do things with your stuff on your phone - mostly delete or just remove back to your com... You can always keep your phone on MAX TAP by using this but always keep space for vids and stuff... (music actually, at least in my Nokia goes to separate file spot. I delete and add all the time music)
Aug 17, 2013 | Nokia Cell Phones
Zte score says i have not enough storage space
Download app2sd application from android market or google market and transfer all the downloaded applications and other data to it, later reboot ur phone. This will fix the issue.
Mar 16, 2013 | ZTE Score
When i dial a number the phone cuts off and restarts
Please try resetting the phone to default settings and it should work. The default code should be the last 4 digits of your phone number unless you have changed it.
Restoring Phone Memory to Factory Conditions
This returns all settings to their factory default value and erases all user data including pictures, video, music, messages, contacts and downloaded applications stored on the phone.
  1. From the home screen tap MENU.
  2. Tap Settings & Tools.
  3. Scroll th screen up and tap 7.Phone Settings.
  4. Tap 5.Security, You're prompted to enter the lock code.The default lock code is the last four digits of your telephone number.
  5. Enter the Lock Code and tap DONE. The security menu appears in the display.
  6. Tap 5.Restore Phone. A prompt appears in the display asking if you wish to restore default settings and erase all user data including pictures, videos, music,messages, contacts, and downloaded applications stored on the phone.
  7. Tap Yes to reset and restore default settings or tap No to return to the Security list.
Mar 15, 2011 | Samsung Glyde SCH-u940 Cellular Phone
Hi ! Every time I try to send a text message, it appears Memory full! Close some applications and try again.I did erase my pics as well as those file saved in my memory card, but it still hopeless. It's 3...
Go your message setting. There is option where you'll save your message and choose save to memory card.
Delete all message in inbox and outbox folder, delete all cache in your browser and close all active applications. Try to send text message.
If the notification "Memory full" still appear you must uninstall a one or more application (not just close it but uninstall it) to make some space in your phone memory. Choose application that you don't use the most.
If the problem persist, format your phone back to factory setting.
Hope this help and if helpful RATE please.
Feb 09, 2011 | Nokia 3230
My nokia 5800 xpress music has just receive a message.thne when i want to open it.it says memory full please close some application.but my inbox is empty.so are my memory card.so how can i fix it?
ur capasity of ur phone is so little u can move the video or any message in the memory of phone into to memory card and if not solved reset factory setting or format the phone try this code *#7370#
Jun 28, 2010 | Nokia 5800 XpressMusic Smartphone
On the screen of my nokia 6600 is mesage (like when you got message) and is moving from one side to a other and rotatating I cant remuvet from there what to do?
format ur phone
try folowwing method..
  • Soft Reset (*#7780#): This is a normal reset. It will load the original settings from the phone's ROM. However, it will retain the user's own data. Like images, music, installed applications etc.
  • Hard Reset (*#7370#): This method completely reformats the C: drive (Phone Memory). All the user information will be deleted. Like images, music files, installed applications etc. Hence, the phone is set to the default factory settings.
On performing any of above methods of formatting the phone, device will ask you for a security/lock code. Default code is 12345.
Data stored on E: drive (MMC) will not be affected by these sequences.
You can also try for the alternative approach.
* Switch Off the device.
* Press and Hold down the keys Green/Talk + 3 + *.
* Switch On the device.
* If everything goes well then you will see "Formatting" screen.
Aug 14, 2009 | Nokia 6600
CECT I9, remove chinese,get java???
Go to the "Call" icon as you would to dial a number manually.
type in the following characters
*#0044#
press the "Call" button as you would to call someone.
You should see a message flash on teh screen saying changed to English.
Check any of your Java appl'n. They should now be in English.
Cheers.
May 21, 2009 | Dual Electronics CECT P168 Cellular Phone
Applications of my N70 music edition cant be opened
its due to virus problem dear.. just format ur phone.. and aviod any unknown bluetooth files accepting.. and provide it with a new fresh memory card with a new antiirus software.. aviraz is a gud antivirus. visit mobile9.com u can find their all softwares.. of any phones.
Dec 19, 2008 | Nokia N70 Cellular Phone
Faulty nokia n72 phone
  • Nov 19, 2008 | Nokia N72 Cellular Phone
    N70 music de freezin
    There might be too many applications running.
    Or too many programs stored ie. Pics, Music, Contacts, Games etc...
    Press Menu for 3 seconds and close the applications by pressing c, one by one. The phone needs a certain amount of memory to operate.
    Otherwise try resetting to original phone settings, in Menu/Tools/Settings/Phone/General/Orig. phone settings.
    Feb 02, 2008 | Nokia N70 Cellular Phone
    Nokia 6288 Cellular Phone Logo
    52 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
