Windows installer problem
I have installing windows installer dialogue box popping up on my screen when I boot up my computer.I am running Windows XP Professional on my computer.I have a 1.7 celeron PC using 512mg of ram.How do I get rid of this problem
  • nigel188 Oct 31, 2008
    preparing to install
  • 749 Answers
WHAT WAS THE MESSAGE ON THE POPPING BOX?
Posted on Oct 31, 2008
I need to fully re-install Windows XP, no matter to lose any information on hard disk, I am using my Windows XP CD and the first device for boot is set to be the CD, but I get Boot Manager missing any way....
Step 1:
Open your anti-virus software program and run a full scan on your computer. Delete all quarantined and infected files when the scan is complete. Insert your Windows XP Install CD into your computer's CD/DVD-ROM drive. Restart your computer. Press the "R" button on your keyboard when the screen says "Welcome to Setup." Type in the admin password when prompted. Press "1" and then "Enter" to open the command prompt. Type "fixboot" into the command prompt. Press "Y" when a pop-up box appears, asking you for confirmation. Restart your computer and you should be taken to your desktop.
Mar 02, 2013 | Computers & Internet
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
HP I let the HP asst. Install a bios update and the install is stuck at 40%. What can I do to get out of the update? HP Probook 4530s
Turn on the computer and begin hitting the "F8" key when you see the BIOS screen.
This will take you to the Safe Mode menu.
Use the arrow keys to highlight "Safe Mode," then hit "Enter" on your keyboard.
This will boot your computer in Safe Mode, a minimalist manner of operating Windows that runs only essential Windows files.
If using Windows XP in Safe Mode, click the "Start" button and then click "Run." In the box that pops up, type "msconfig" and hit "Enter."
If using Windows Vista or Windows 7, click the Windows logo in the bottom left corner of the screen, type "msconfig" in the search field and then hit "Enter."
This will open the System Configuration Utility.
In the System Configuration Utility box, click the "Services" tab, check the box that reads, "Hide All Microsoft Services," click "Disable All" and then click "Apply."
In the System Configuration Utility box, click the "Startup" tab, click "Disable All" and then click "Apply." Next, click the "Close" box.
A box will pop up that prompts you to restart your computer.
Select "Restart" and let the computer restart itself, allowing it to boot to Windows normally.
If the computer still stalls when trying to boot to Windows, restart the computer and boot to Safe Mode again.
Run your antivirus program in Safe Mode, deleting any files that are flagged as viruses, spyware or malware. Restart the computer and boot to Windows normally
hope this helps
Sep 29, 2012 | Computers & Internet
hope this helps
When i turn the computer on it says windows root 32 is corrupt or missing please reinstall but i cant get it to reinstall it the install menu does not pop up
You need to re-install it using your disc not when your on Windows enable for it to install. Here are the steps to install Windows back in your system.
  1. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  2. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  3. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  4. Read the Microsoft Software License Terms, and then press F8.
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows .
  6. Follow the instructions on the screen to complete the Windows Setup.
Sep 12, 2010 | E-Machines eMachines Desktop PC
I have a problem with my PC: When I try to turn off the windows XP home edition SP3 the pc don't stop he restart, but i think the HDD C: where windows is install stop and then restart all sistem (like in...
It Seems Some System Files are Corrupted or Deleted By Antivirus Application in the Process of Removing Virus from your System ....
Method 1:
1. Put your Windows XP CD in your CD-Drive
2. Open RUN Dialogue Box From Start Menu
3. Type "SFC /SCANNOW" -- Copy and Paste the Command exactly
With out Quotes
4. Wait Until It Completes everything...
5.Restart and Check your Problem ....
Method 2:
1.Login to your Windows XP
2. Put your Windows XP Home CD in your CD-Drive
3. Click Install Windows XP From Autorun Window.Start Windows XP Autorun Screen if its not opened, by Clicking on the Windows XP CD Drive icon under your My Computer ...
4.Select Same Drive as your Windows XP Now Installed then Select Upgrade Method to Install...
5.Complete Installation and Restart your System ...
Note: in Upgrade You'll never lost your Installed Programs and Files ...
Feb 20, 2010 | Microsoft Windows XP Home Edition
I have done a system recovery, it reinstalls and requests that I restart, after the restart it does more install and freezes, it never completes.
It happence Due to File Curreption or Mismatched System Files...
Put your Bootable Windows XP CD in your CD-Drive/DVD-Drive..
Boot from CD and Select Repair Windows XP...
Select your Windows Installation Drive to Login
Run Some Command From Restore Command Prompt
-- X: is your Windows XP Home Drive
X:\chkdsk /f /r
NEXT
X:\fixmbr
X:\fixboot c:
Restart your System ... Open RUN Dialogue Box from START Menu
Type this Command
Run --> "SFC /F /R" <Press Enter> Paste Without Quotes ..
Wait Until Complete System Check ,then Restart your System
If you want more Usefull Methods Visit this ....
http://www.webtree.ca/windowsxp/repair_xp.htm#How%20to%20Repair%20the%20Boot%20Sector:
Feb 19, 2010 | Microsoft Windows XP Media Centre 2005 for...
Trouble Installing COSMI Perfect Accountant Platinum
I'm Working as a Technician! You can explain your problems to me by dialing my toll-free number +1 (844) 355-5111.
Regards
Jun 30, 2017 | Cosmi Perfect Accountant Platinum...
I'm not a blonde- but the damn GE Easycam is making me crazy.
Marueen, GE computer accessories are now sold and supported by Jasco. Their download page has drivers for your webcam; unfortunately they don?t have any Vista certified drivers. Unfortunately lots of hardware manufacturers are not creating new Vista capable drivers for older equipment and I suspect Jasco will follow the trend as well. You can try downloading the latest XP driver from their site and seeing how it works but in the long run you may just be better off getting a more mainstream product with Vista drivers. Jasco download page: http://www.jascoproducts.com/cgi-local/SoftCart.exe/online-store/scstore/pro/computer_software_cams.html?L+scstore+ndrt4702ffcebece Let us know if you have any other questions and please don?t forget to rate this post.
Apr 03, 2007 | GE EasyCam Webcam
Computers & Internet Logo
David Payne
David Payne
