Question about Panasonic CT-27G23 27" TV
Picture tube doesn't turn off
I have a Panasonic CT-31G30T television that is 10 years old. When I turn the power off with the remote or the button on the front of the TV, the picture tube will sometimes stay brightly lit and not turn off. By turning the power off/on a few times the picture tube may turn off sometimes; other times I have to unplug the TV. The problem is intermittent and not always there. Any idea what the problem is and what a ball park cost to fix might be?
  • ela3swim May 02, 2008
    I have the same problem. The tv will not turn off at the tv or from the remote. We have to unplug all the time which can be very annoying (how lazy can we be, huh?).
    If it is the relay, how do I take care of this? Does it have to go to a tv repair person or can it be done by an unprofessional? thanks a bunch!
    President:
  • 3,130 Answers
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Posted on Sep 15, 2006
The picture on my 31"
It sounds like the tube has burnt out. Now that price of lcds have come down especially in that size class it will cost just as much to repair as it would be to purchase a new tv.
Aug 11, 2011 | Panasonic CT-36D32 36" TV
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
Panasonic CT-32SL14J green picture after blown fues replaced
no there may be loose contact or dry solder in circuit board attached to tube..ie video driver section ..resolder
all the solder joints cleanly...&also resolder the long ic ie
chroma ic...u can find where the problem is by gently tapping the main board or video board by a tooth brush
when tv is on. if the color changes by tapping u can get the loose contact..have a nice day
Mar 10, 2010 | Panasonic CT-32SL14 32" TV
I have a Panasonic 32" tube television that is only 6 years old (Model CT-32D31) that we bought from Sears. We suddenly have nothing but a horizontal white line across the screen, which "grows" into a...
Sounds like 'bad' or 'dry' capacitors in the vertical deflection circuit. Please note that leaving the white line on the screen too long can burn in the screen, which is permanent damage.
Jan 31, 2018 | Panasonic CT-32D31 32" TV
Power just quit had a great picture
panasonic tv's suffered from frame chip problems causing them to be stuck in stand by .not an expensive part though...
Apr 25, 2009 | Panasonic CT-32SL14 32" TV
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Panasonic tv old model
curve picture and auto shutdown
May 10, 2008 | Panasonic CT-20D11 20" TV
Panasonic CT-27D12D turning off on it's own
it sounds like a DRY SOLDER somewherein the PC board where the POWER SUPPLY located , I suggest , if your HANDY with this procedure, Im sure you can get it fix , FIRST lets remove the back cover to get inside the TV ( if TV was recently turn ON , you need to unplug it and wait till the next day to do procedure , cause the picture tube acts like a BIG capacitor reserving electricity,cause we goona need to remove that big RED round rubber plug to the tube ) . to make it short , you need to remove the PC BOARD and look for any dry solder , and resolder it ,that will take care of this problem
Apr 18, 2008 | Panasonic CT-27D11 27" TV
No picture no sound nothing
We had a TV repairman look at our 3 year old (Oct 2004) Panasonic CT-32HXC14J FLAT SCREEN TV. It suddenly stopped working and appeared to have no power getting to it. It was a high voltage supply or transformer that was bad and has to be replaced - estimated cost is around $400. In a year we will also need to spend around $125 for a digital converter box. We went for the repair since that is still cheaper than a $1,000 plus equivalent size LCD or plasma.
Our old tube tv was still working after 15+ years. They aren't making them like they used to. Way to go Panasonic.
Nov 09, 2007 | Panasonic CT-32HXC14 32" TV
My Panasonic Television
sounds like you either have a bad vertical deflection ic, or a bad resistor supply power to the ic. i'me not sure of the location, but panasonics usually put it in ic401.it is a ic with 10 to 16 pins all in a row. it will ne screwed to a small heatsinkthe making on the ic should start with laXXXX. x being numbers. good luck
Feb 05, 2007 | Panasonic CT-32D30 32" TV
Panasonic CT-27G23 27" TV Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
